R50/53 Belt Tensioner Tool
Old Jul 15, 2017 | 10:01 AM
nealsmini's Avatar
nealsmini
Belt Tensioner Tool
Does anyone here know where I can purchase the lock pin for the belt tensioner on a '05 MCS? The tool I purchased did not come with the tool.
Old Jul 15, 2017 | 10:36 AM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
It is just a bend piece of steel wire. You can find a surplus allen wrench around the house. Even a right dia rusty nail will do.
Old Jul 15, 2017 | 11:37 AM
nealsmini's Avatar
nealsmini
Thanks for the response - I did think of that but I would like to get the correct tool for the job.
Old Jul 15, 2017 | 01:27 PM
Cenla Mini's Avatar
Cenla Mini
Nealsmini...you can also get a paint can opener at Home Depot and use it...there really isn't anything special about the lock pin...mine isn't much more than a paint can opener that's had the tip rounded off.
Old Jul 15, 2017 | 01:36 PM
nealsmini's Avatar
nealsmini
GREAT IDEA! Thanks
Old Jul 15, 2017 | 10:43 PM
sarom058's Avatar
sarom058
From: Portland, OR *currently in a temporary email address
An allen key and some needlenose plyers to hold the key works fantastic! Not sure if you'll be able to find just the pin tool anywhere.
Old Jul 16, 2017 | 04:52 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
He is correct, or you can use a small pocket screwdriver.
Old Jul 17, 2017 | 06:09 AM
AoxoMoxoA's Avatar
AoxoMoxoA
You can make one from something that you probably have hanging around at home...
Never a fan of the two-part pliers/lock pin method, I simplified the process into a single piece unit, making mine from a paint roller handle that I straightened, then bent at the end. About a foot long, and makes the task much easier.
Old Jul 17, 2017 | 10:05 AM
z_wrecker's Avatar
z_wrecker
I had a steel wire that I bent so when I push on the tool I can just reach it without much movement. I wasn't a fan of the little tool that came with it. It was too short
Old Jul 19, 2017 | 12:41 PM
nealsmini's Avatar
nealsmini
THANKS so much for all the help - I have lots of options to create a tool!
