Code: 2AD2 ??
Old Jul 12, 2017 | 02:20 PM
imncrxtc's Avatar
imncrxtc
Code: 2AD2 ??
Hi guys, my car had a check engine on for some time now. I had it scanned today, and this is the code that came up:
2AD2 Oxygen Sensor after catalytic converter dynamic response in overrun.
Any thoughts?
Old Jul 12, 2017 | 03:31 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
How many miles on your car? What car do you have? Sensors eventually go and need to be replaced. If you do change it out stick with OEM.
Old Jul 12, 2017 | 05:38 PM
imncrxtc's Avatar
imncrxtc
I should have lead with that
2008 Justa, 200,000 km.
Old Jul 12, 2017 | 05:54 PM
Minnie.the.Moocher
If those are original sensors you did well.
Old Jul 13, 2017 | 04:04 AM
imncrxtc's Avatar
imncrxtc
which sensors?
Old Jul 14, 2017 | 06:28 PM
AZdsrt's Avatar
AZdsrt
I suggest replacing the o2 sensor, the one past the cat..
Old Jul 17, 2017 | 11:40 AM
imncrxtc's Avatar
imncrxtc
I thought the downstream O2 didn't do much.
Old Jul 18, 2017 | 03:17 AM
JCdubGerm's Avatar
JCdubGerm
Replace the o2 sensor. They do go bad and are easy to replace.
Old Aug 5, 2017 | 05:37 AM
seandallen's Avatar
seandallen
The ECU compares the output of the pre- and the post-cat sensors to make decisions on fuel & air metering. So they're both important. If the error code indicates a problem with the sensor, and not with something in your fuel or air (like a fugitive leak), then you should just change them out.
Your error code seems to indicate a problem with the sensor itself, so, yes, change it, or better yet, change both. At 200,000km, you've gotten about 40,000 more kilometers more than they're rated for. Consider that a win.
