Suspension Powerflex LCA Bushing Install
Old Jun 28, 2017 | 09:42 AM
IslandJCW's Avatar
IslandJCW
Hi everyone,
In the middle of some maintenance on my 05 JCW so thought I would take the opportunity while the subframe was out to install some PowerFlex bushings… Which should be simple enough
Question… Has anybody here had issues installing the LCA bushings into the carrier?…
I've got all the right tools, but cannot for the life of me get these poly bushings to insert into the sleeves!
These bushings don't have much give and the leading edge just seems far too large to be squeezed into the receiver no matter which way I attempt.
Bushings are verified as the correct ones… Receiver is cleaned and lubricated as is the poly leading edge
Any insight would be appreciated!
Old Jun 28, 2017 | 09:50 AM
gumbedamit's Avatar
gumbedamit
What tools are you using to get them in? I have the PowerFlex bushings but haven't gotten around to installing them. I did purchase this tool to put them in:
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Can't really tell you if it works.
Old Jun 28, 2017 | 09:55 AM
IslandJCW's Avatar
IslandJCW
Got that same kit as well as a home made kit using threaded rod and floor flanges, nuts and washers .. used home kit with other vehicles (BMW) , but first time on MINI
Old Jun 28, 2017 | 06:23 PM
IslandJCW's Avatar
IslandJCW
Update on PowerFlex LCA Bushing Install
After several failed attempts at installing the PowerFlex LCA bushings into the carrier bores... what I found works for me was to freeze the bushings overnight which actually shrunk them down .3 mm…
That was enough for me to persuade them into bores..still very tight but much more doable
Old Jun 29, 2017 | 07:44 AM
gumbedamit's Avatar
gumbedamit
Great news, I did see that method on a youtube video. When I do mine, they will go into the freezer first...
Old Jun 29, 2017 | 08:48 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I would think that dropping them into some hot water would make them a little more flexible, allowing the bushing to smoosh easier.
