R50/53 R53 - 100k miles
Old Jun 19, 2017 | 07:58 PM
MiniTigger's Avatar
MiniTigger
R53 - 100k miles
2006 R53 .. coming up on 100k miles. Anything specific I should be servicing / changing?
I've had the car for a year - all fluids have been changed and I have begun 'normal' maintenance - ie: oil changes, etc.
Old Jun 19, 2017 | 08:54 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Depends on what maint you have already done. But we typically do the fuel filter at 100k
https://www.waymotorworks.com/fuel-f...0-r53-r52.html
Old Jun 20, 2017 | 05:12 AM
CSP's Avatar
CSP
Not necessarily changing, but definitely visually inspect suspension bushings and ball joints, inspect coolant reservoir for leaks, OFHG for leaks, VCG for leaks. Might be beneficial to do the motor mounts.
Doesn't the supercharger typically need some maintenance around then?
Old Jun 20, 2017 | 05:19 AM
HillbillyChili's Avatar
HillbillyChili
Agreed, definitely want to check the motor mounts and maybe look into start replacing the "lifetime fluids" like transmission and brake fluid.
Congrats on the milestone!
Old Jun 20, 2017 | 05:25 AM
Whine not Walnuts's Avatar
Whine not Walnuts
What is the history of the car? Are you the first owner? If not first owner, when did you purchase? What type of normal maintenance was performed by you or a previous owner?
Old Jun 20, 2017 | 08:40 AM
MiniTigger's Avatar
MiniTigger
I have had it for 1 year. I have changed all fluids - oil, cooling, brakes, trans.
Old Jun 20, 2017 | 09:05 AM
AoxoMoxoA's Avatar
AoxoMoxoA
Originally Posted by MiniTigger
2006 R53 .. coming up on 100k miles. Anything specific I should be servicing / changing? I've had the car for a year - all fluids have been changed and I have begun 'normal' maintenance - ie: oil changes, etc.
Check out my post (post #4) from THIS thread...
Old Jun 20, 2017 | 12:54 PM
MiniTigger's Avatar
MiniTigger
Link doesn't work. Doesn't appear to link here.
Old Jun 20, 2017 | 01:09 PM
AoxoMoxoA's Avatar
AoxoMoxoA
Works for me when I click it...
Old Jun 20, 2017 | 03:24 PM
MiniTigger's Avatar
MiniTigger
Works now - I saw that .. that's what inspired this one.
Old Jun 22, 2017 | 04:51 AM
IQRaceworks's Avatar
IQRaceworks
My shocks, ball joints, tie rod ends, and LCA bushings were all shot at 80,000 miles. Definitely inspect all of those and any other suspension components you can think of.
I've got a little over 150,000 on my car now....still chugging along just fine
