2004 Automatic will not turn over!
Old Jun 19, 2017 | 03:50 PM
Mini_Cooper_'s Avatar
Mini_Cooper_
Okay okay, I know I'm about to get blasted with comments saying you should have just searched the internet because there are hundreds of threads about this. Ive looked through them all, hoping I won't have to get this thing towed to a mini dealer.
Work started off replacing both front wheel bearings. Then both front Axel's. Since all the transmission fluid exited, I refilled it. In order to do that I had to take the battery out along with the brainbox next to it. Took the battery out first then the brain, then put the brain back in and then reconnected the battery. Car will not start.
Put the key in and it dings so it's not immobilized( or so I hope), then all the dash lights come on. Fuel pump runs. Hear some other stuff happening under the hood as well. Checked the ignition switch thinking it would be simple, contacts are all good. Reset the ECU via dash (hopefully not a bad thing). Still nothing.
Pulled a working battery with the same cranking amps and it does the same thing. I have not checked the starter and if I did I would need a little bit of guidance. Just a little frustrated! I've read about the immobilizer brain can go bad if the battery goes down or I'm sure if the ECU gets disconnected and it needs to be resynced, and of course only a mini dealer can do it.
Old Jun 19, 2017 | 04:12 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Moving this to the Stock Problems/Issues area.
When you worked on the car, did you disconnect the ground strap near the passenger side motor mount? I would also assume the car has an interlock via the transmission to the key. Did you remove anything on the transmission other than axles?
Old Jun 19, 2017 | 04:20 PM
Mini_Cooper_
I did not remove the ground strap. I just made sure it was tight. No dice. I only removed the Axel's and did not touch anything else. The key will fully turn in any gear which leads to believe it is an interlock problem.
Old Jun 19, 2017 | 05:07 PM
Whine not Walnuts
Do not confuse the ability to turn the key with an electronic interlocking relay from the ignition switch to the starter, or to the engine. Below is a thread that details the relays and fuses. I know that R1 relay controls the power to the engine. If the grounds are tight and you have good voltage, I am still thinking that a control circuit is loose.
https://www.northamericanmotoring.co...nd-wiring.html
Old Jun 19, 2017 | 08:12 PM
Mini_Cooper_
Okay I just checked and double checked all the fuses in and out of the car. Found a blown cigarette lighter fuse and replaced that. The relay you mentioned seemed alright, I swapped it with a known working one. Still nada. I checked the battery voltage and it was sitting at 12.00v it's on the charger now. What do you mean by loose connection? Are there certain ones that I should look for? Thank you for replying and helping me out.
Old Jun 20, 2017 | 05:22 AM
Whine not Walnuts
Would assume some electrical gurus will chime in but there are different types of relays. In some instances a relay connects a high amp circuit (power), such as the starter, by using a low amp circuit (control) to "close" the heavy amp switch. I am assuming the R1 relay has several pins and therefore there are several functions that most occur before the heavy amp/power switch will close. You changed relays but I assume did not test to see if the control circuits were functioning correctly.
At this point I would test to see if the starter solenoid is getting voltage. This is a two person job and you need to have somebody turn the key while you are testing the starter. The issue is that the Mini starter is in one tight spot. You would also need to check the main power connection to the starter (the thicker wire) to see if there has been any corrosion. Here is a link to a starter video.
The car worked before you did any work. You worked on the transmission and disconnected the battery (usually all you need to do is remove the ground/negative strap at the battery). Logically the issue is at one of these two areas.
Old Jun 21, 2017 | 01:53 PM
Mini_Cooper_
​​​whew! It was a connector on the transmission right below the driver's side axel, I must have knocked it loose. After that it started right up! Thank you so much for helping me out and pointing me int he right direction.
Old Jun 21, 2017 | 06:15 PM
Whine not Walnuts
No thanks needed, we Mini people need to stick together. User error happens allot here.
Old Jun 22, 2017 | 10:11 AM
Wow after reading that glad it was something simple, i was going to say check the plugs and the ignition switch.
