Navigation & Audio Blown speaker
Old Oct 7, 2004 | 04:53 AM
atn57's Avatar
atn57
Blown speaker
Good morning everyone,
I think I have a blown speaker already and it has only been like 6 months. Do any of you guys know the warrenty on these things? Has anyone gotten they replaced under warrenty? I just have the regular speakers as well.............
Please help
thanks
ant
Old Oct 22, 2004 | 01:47 PM
WEB-FX's Avatar
WEB-FX
Speaker problem from day one
I have a 2004 S and the right front speaker has had a rattle (for lack of a better term) since the day I drove it home. I thought at first it was just my imagination but, I have had several people now tell me they can hear it & in fact it is getting worse.
If anyone has any advice - I would like to hear from you...
thx
ps. I've had Excalibur for just less than 1 year now - I have the factory HK system.
Old Oct 22, 2004 | 05:18 PM
Cooperb!'s Avatar
Cooperb!
thx
This is a common 'feature'
The fix is actually quite simple.
the rattle is caused by the plastic door skin being a loose fit to the metal door.
To fix the rattle, open your right hand door
Run your hand around the plastic door trim, go down the hinge side, around and under the corner where the bass speaker sits.
Flex the door skin with your fingers, you can pull it away ever so slightly from the metal of the door, and that's why it rattles.
FIX: You need to insert a strip of plastic or cardboard, between the plastic skin and the metal door.
I used a thick tie-wrap.
I pushed it in at that bottom corner, under the speaker area, and positioned it so it lay along the edge of the plastic door skin.
I did one on the bottom horizontal edge, and one on the hinge side vertical edge.
Problem solved, no more rattle!
You can ue some double sided tape to keep it in place once you've proved the fix is good.
I bet your 'blown' speaker is in fact this rattle - it sounds like a blown driver, but it's just the poor fit of the plastic trim of the door!
Chris.
Old Oct 23, 2004 | 07:15 PM
lacken's Avatar
lacken
OK ...I went through the standard fix for this problem.
It seemed to work for a while, but gradualy started bothering me again.
Upon taking it back to the dealer it was deemed "a component problem"
and the right front components were replaced. It was warrenteed.
The speakers now sound great.
Old Oct 24, 2004 | 04:50 AM
Mrazda's Avatar
Mrazda
Chris.
just tried this and it works great
thanks
Old Oct 24, 2004 | 05:36 PM
Cooperb!'s Avatar
Cooperb!
thanks
Gotta love that std feature on the MINI
Glad it worked for you too - and much quicker than getting replacement driver!
Now all I need to do is fix the door rattle - top right, and I'll be happy
Chris.
scottselk
Jul 20, 2019 06:43 AM
PsychoRallye
21
Feb 17, 2019 06:08 AM
vulkandino
Oct 31, 2015 08:29 PM
patsum
Oct 1, 2015 06:33 AM
silence2-38554
Sep 28, 2015 12:19 PM
