What offset can a mini cooper s fit?
Old Oct 7, 2004 | 04:08 AM
tl915's Avatar
tl915
I am looking at a set of 16x8 wheels which have offset of +35, +42, +49
and a set of 17x7.5 wheels which have offset of +33, +43
so here is what i am looking for, the deepest lip. i want it to look good with a deep feel. which one should i get, and can anyone tell me the difference of the offsets? thanx
Old Oct 7, 2004 | 06:16 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
tl915,
For an MCS with stock suspension
16x8 wheels with +42mm and +49mm offsets will fit (+37 to +50mm is OK)
17x7.5 wheels +43mm offset will fit
For MCS with lowered suspension
16x8 with +42 and +49mm offset will fit (+42 to +50mm is OK)
17x7.5 with +43mm offset will fit
These are general ranges but your exact suspension may vary a small amount with upgrades and with the load in the MINI, the squareness of the shoulder of the tires, and the outer diameter size of the tires.
Old Oct 7, 2004 | 10:16 AM
tl915's Avatar
tl915
I want a small offset so i get the lip effect. I currently have a set of rear sway and h&R spring. going to upgrade to coilover later this month
Old Oct 7, 2004 | 10:30 AM
d6-mcs's Avatar
d6-mcs
as some people know and have seen my car i am running a 17x8 et35 in front on a 205/40/17 and in the rear i have 17x9 in a 215/40/17, believe me a 16x8 with the et of 35 will fit just fine. i have about a inch of clearence on inner rear subframe and about a inch of clearance between my front strut and my wheel. so you should be fine. good luck
IM if you need anything
chris
Old Oct 11, 2004 | 04:34 AM
tl915's Avatar
tl915
thanx for the info Chris, love your rims! I am looking for some ASA AR1 18 or 17
Old Oct 15, 2004 | 05:12 AM
Aqualung's Avatar
Aqualung
How About for 15"?
I'm going to call around to some dealers for some used rims. What should I say to spec 'em for offset? And, anything else (thinking of the lug holes, etc).
I have a stock MCS w/ no alterations.
thx.
Old Oct 15, 2004 | 08:48 AM
Alex@tirerack's Avatar
Alex@tirerack
thx.
Its hard to say a specific offset works, because wheel design influences the fit. Most 7's from 40-45 fit really well. Some for 37-40 can fit with light mods.
Alex
Old Oct 15, 2004 | 03:06 PM
tl915's Avatar
tl915
is it possible for me to fit a wheel the following size?
- 16x8 +35
- 17x7.5 +33
- 18x7.5 +38
if possible how should i do it?
Old Oct 18, 2004 | 10:38 AM
Alex@tirerack
- 16x8 +35
- 17x7.5 +33
- 18x7.5 +38
18 may fit, other 2 a really agressive!
Alex
Old Nov 7, 2004 | 07:50 AM
gowest's Avatar
gowest
I just got a set of 16x8, +42, ce28n's. The wheel, by it self, clears the front strut by 2mm. I took a measurement in the rear but don't remember the exact number but it was in the 4-6mm range. My car is lowered, so getting a tire to fit without rubbing the fender in the rear or the strut in the front may be difficult and may require a spacer in front but I bought these mostly for autocrossing so I can go to odd size tires if needed and think the 215/45/16 Falken Azenis, I have on my other car, will fit anyway.
This sounds like the wheel the original poster was asking about, judgeing by the offsets, but I should mention that these wheels are forged aluminum and are probably thinner in the critical area of front strut clearance than any cast aluminum wheel would be. My 15x7.5, +43, SSR's only clear the rear trailing arm by 1 mm and they flex that much under load in an autocross so I use a 1/16" spacer on the rear.
Wheels with less offset in the same design, ie +35, would give you a deeper lip but would require a smaller diameter tire or a much stiffer supension or both not to rub in the rear.
Old Nov 10, 2004 | 01:49 PM
tl915's Avatar
tl915
can you post sone pic of the ce28n installed
Old Nov 11, 2004 | 06:55 AM
gowest's Avatar
gowest
They are not on the car yet and I don't have a digital camera anyway but there are pictures of ce28n's on this forum and mini2.com somewhere. The dealer neglected to send me any hub centering rings.
Old Aug 25, 2017 | 04:22 PM
hunterrileyortiz's Avatar
hunterrileyortiz
chris
I need help would a 16x8.3 wheel with a 25mm offset fit my 2004 Mini Cooper s with stock suspension
SosoMINI
Nov 22, 2015 03:17 PM
Mini'mon
Aug 16, 2015 04:15 PM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
