Radiator replacement advice
Old Jun 15, 2017 | 07:04 PM
backsidedriver's Avatar
backsidedriver
I have discovered a hole/leak in the top right front of my radiator. In considering a replacement are the aftermarket brands good or should I stick with the high priced OEM radiator?
Also any advice from those that have replaced their own radiator before? Any gotchas I should be aware of?
Old Jun 15, 2017 | 09:11 PM
ItsmeWayne's Avatar
ItsmeWayne
I am all about the full aluminum radiator. Some may argue, but plastic tank radiators have a 100% leak guaranty over time and never at an opportune moment.
and don't forget to replace the fan speed control on the radiator holder. They always go bad also!
Old Jun 16, 2017 | 02:48 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Looking at your posting history, is this for an '04 R50? If you don't want to go with the Genuine MINI radiator, I would recommend CSF: http://www.pelicanparts.com/catalog/..._pg1.htm#item3. Very good quality. I've run a few of their racing radiators. They are well spoken about in the Porsche community as far as quality and performance as well. They might make a full aluminum one for the R50, but not sure. I can check, but also echo what was said above about going full aluminum, personally.
Be sure to check out our DIY for help and suggestions on parts to replace while doing the job: http://www.pelicanparts.com/techarti...eplacement.htm.
Let me know if you have any questions.
888.280.7799 | 6am - 5pm PST
Old Jun 16, 2017 | 04:46 PM
backsidedriver
You are correct, this is a 2004 Mini Cooper Base R50 Hatchback with Automatic Transmission.
Old Jun 16, 2017 | 04:58 PM
backsidedriver
Looking at other posts it appears they do not make an aluminum radiator for the base model, only the S. Guess it will be a plastic one. I'll look at your links. Thanks.
