What do wheels weigh?
Old Oct 5, 2004 | 06:56 PM
62Lincoln's Avatar
62Lincoln
I have read elsewhere that S-Lites weigh 25.1 pounds: http://www.mini2.com/forum/showthread.php?t=41956
I'm considering replacing my S-Lites with the JCW 18" wheels, and wonder if anyone knows what the JCW's weigh?
Old Oct 5, 2004 | 07:04 PM
kyriian's Avatar
kyriian
according to mini2, the r95 spider spoke weighs 23.5 lb, or about 10 kilos
http://www.mini2.com/forum/faq.php?f...factory_wheels
Old Oct 5, 2004 | 07:50 PM
Verruckt's Avatar
Verruckt
I know there is a thread on this somewhere.. do a search. I can't remember the numbers, but I seem to recall people bemoaning the high weight of the JCW 18" wheels. For your sake, I hope I am wrong.
Old Oct 5, 2004 | 08:14 PM
los_blankeys's Avatar
los_blankeys
i think the info is in the sticky at the top of this forum...
Old Oct 6, 2004 | 01:43 PM
62Lincoln's Avatar
62Lincoln
The only info I've been able to find is an obscure reference that stated that a 'reliable source' said the JCW wheels weighed 2/3 the weight of an S-Lite wheel. I guess that's possible, but I'd like something more definitive.
Old Oct 6, 2004 | 10:29 PM
Ryephile's Avatar
Ryephile
JCW 18"s with Dunlop 205/40-18 runflats weigh in at about 48 pounds a corner. S-lites with Pirelli Euforia's are about 45 pounds a corner, and S-lites with Goodyear RS-A's are 50 pounds a corner, typically.
Old Oct 7, 2004 | 04:13 AM
62Lincoln's Avatar
62Lincoln
Ryephile, thank you for pitching in. I used your info, and looked at the sticky above for tire weights, and things don't add up. The Pirelli and Goodyear tires are only listed in the 205 45 17 section, so assuming that is the correct size, their respective weights are 8 pounds apart. And of course (my usual luck), the Dunlops are not listed. Any ideas?
Old Oct 7, 2004 | 09:57 AM
MINIAC's Avatar
MINIAC
From the MINI2 FAQ:
R95 spider-spoke (aka JCW alloy) ET52 23.5lb (10.7kg)
205/40-18 Dunlop SP Sport 01 DSST 24.0lb (10.9kg)
Old Oct 7, 2004 | 03:40 PM
62Lincoln's Avatar
62Lincoln
Thank you, MINIAC. :smile:
P.S. And thanks to Kyriian, as I did not realize the JCW was also known as the R95.
Old Oct 7, 2004 | 05:17 PM
BlueMCS's Avatar
BlueMCS
Worst move you could make unless you are solely into bling. Think 16" and as light as you can afford.
Old Oct 7, 2004 | 05:53 PM
Ryephile's Avatar
Ryephile
*I've found some the tire weights in Alex's listings are not correct.
*16" vs 17" vs 18" decision is solely up to the MINIac and their application/needs. BlueMCS does lots of racing, and with stock brake sizes, without much care for "car show bling", so 16's are best for his application.
Old Oct 13, 2004 | 11:00 AM
bluesmini's Avatar
bluesmini
i have a spare S-light with a pirrelli run-flat on it and it weighs in at 51.5 lbs. it got maybe 100 miles on it before i bought it.
Old Oct 13, 2004 | 11:24 AM
meanboy's Avatar
meanboy
Wow! I took off the S-lites with dunlops and they must weigh at least that. Heavy!
Old Oct 14, 2004 | 05:43 AM
onasled's Avatar
onasled
Found this site http://www.wheelweights.net/Maybe you know about it, but great wheel weight info!
Old Oct 14, 2004 | 07:04 AM
Alex@tirerack's Avatar
Alex@tirerack
Alex does not weigh tires, he used manufacture's suppied weight. Alex does weigh wheels inhouse though.
Alex
Old Oct 14, 2004 | 07:10 AM
toddtce's Avatar
toddtce
Wow, talk about a data base. Even if the info is only 90% accurate the numbers are huge. Somebody has way too much time on their hands!
barnoun
Sep 17, 2018 05:04 PM
khumpert
Nov 30, 2015 11:48 AM
SosoMINI
Nov 22, 2015 03:17 PM
Tires, Wheels & Brakes
Aug 26, 2015 11:02 AM
JHolland
Aug 24, 2015 07:04 AM
