Lug bolts for Kosei K1 TS 17x7
I am receiving a used set and I wondering if anyone knows what size lug nuts I need and what the part number for locks could be. I called Tirerack but they would't sell me any or give me any information since I didn't buy new ones from them. Can't say I blame them...although I think they probably lost me as a future customer.
I have the same wheels and ended up using the stock lug bolts which are a dark finish instead of the ones that came from tire rack which were a bright nickle plated and looked like crap with the grey wheels, The ones supplied were the same size as the stock, you will have to use a thin wall socket to torque them down , the Mini Supplied lug wrench is too thick walled and won't fully engage the head of the lugbolt so you will round corners and scratch the finish on the wheels
I have had problems with the center hubs popping off as I there is a size interference problem and they have a very thin engagement lip. They get pushed thru the wheel by the concentric hub rings. BTW get the aluminum ones (hub rings)51mmm I think
I will attempt to post a pix below
Hope this pix isn't too big?? Not sure what you mean by wheel locks, but be sure that you get the correct Concentric hub rings(alum) the first ones I rec'sd were plastic and the wrong size the wheels slipped and went outa balance big time, I called Alex at Tire Rack and he was great in getting me the correct concentric rings, even tho I had ordered thru one of their sub vendors. Alex is the MINI Guru and will now what you need, good luck:smile:
Excellent..thanks for the picture. I just went to the mcgard site and the size they stated was 12m x1.5 bolt. Here's a pic of the what I was thinking as far as a wheel lock.
Thats our wheel, we know what fits. Why didnt you call me??
Alex
Alex
Alex
Alex
Damn: I want those Kosie K-1 TS in white sooo bad. Did get a quote from local body shop who, are very picky with what they work on ("Nice cars or nice people's cars"). They turn out fanstic work. Quoted me $50.00 per wheel. I think thats a deal.
Nicefeet
Sep 24, 2015 06:53 PM
