crank position sensor O-ring
Old May 24, 2017 | 05:37 PM
coopermike29's Avatar
coopermike29
Is it a difficult job to replace ?
2006 R 50 auto
Thank you
Old May 24, 2017 | 06:30 PM
Whine not Walnuts's Avatar
Whine not Walnuts
On the S you have to put the car in front service mode but I am wondering on yours without the supercharger whether you can access the bolt to pull the sensor out.
How many miles on your car and when was the tranny oil changed last as you have the cvt.
Old May 24, 2017 | 08:27 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
It's not too bad esp since it's a non S. Look at the instructions in the manual and see what you think of doing it.
If you need it we stock them
https://www.waymotorworks.com/cranks...or-o-ring.html
Old May 25, 2017 | 05:25 PM
coopermike29
Thanks r53coop and WMW
Car has 110,000
tranny fluid change at 107,000
VERY CLEAN
Old May 25, 2017 | 05:28 PM
coopermike29
Does anyone have a pic of this on where it is located ?
Has anyone ever done one ?
Thank you all in advance
much appreciated
Old May 25, 2017 | 05:55 PM
Whine not Walnuts
The crank sensor is on the bottom of the engine, about dead center of the radiator, 6" up from the bottom of the engine (going by memory). The bolt that holds it in place is on the top side, you need to remove the electrical plug before you remove. Once loose, it pops out and the o-ring takes at most a couple of minutes to replace. If its been leaking you have about 1/4" of goo on the block that you should wipe/clean off.
ModMini has a video about accessing the AC unit from below if I remember correctly, he disconnects the rear bottom engine mount and then uses a come along to pull the engine back. This gives you more room to get up in between the engine and the radiator without going into Front Service Mode.
Old May 26, 2017 | 12:44 PM
coopermike29
thanks again r53coop !!!!
Excellent info as always !!!!!!!
