Any experience or tips on cleaning throttle body and manifold
Old May 24, 2017 | 01:47 PM
sikamini's Avatar
sikamini
I'm in the process of cleaning up after a failed turbo. Replacing misc items and cleaning the remainder. I took the throttle body and intake manifold off to clean and inspect the intake ports. Cleaned them a few years ago and they don't look too bad. However, when I pulled the air hose off the throttle body a bunch of oil dropped out. I suspect that came from the turbo. Last time I had the throttle body and intake off I just superficially cleaned all surfaces with a cloth rag. Now I'm wondering if a cleaning might be in order. I'm thinking Dawn liquid wouldn't hurt it. Thoughts appreciated.
Old May 24, 2017 | 05:22 PM
sikamini's Avatar
sikamini
With the throttle by wire it's a piece I want to treat carefully.
Old May 24, 2017 | 05:27 PM
sikamini's Avatar
sikamini
This is the curved portion of the tube at the throttle. Note the residue. Also found a fair amount of oil.
Old May 27, 2017 | 07:24 AM
sikamini's Avatar
sikamini
I can't be the only one ever to take this part out. It's my second time and second time cleaning intake valves. Last time I had it out, I just wiped it with a soft cloth, but this time there was more oil. From the other thread I may consider a catch can in future mods. I'll take a bit of Dawn and water to it for now. I have a bunch of tubes still to degrease.
Old May 30, 2017 | 08:00 AM
sikamini's Avatar
sikamini
Well it's going back in today. Used Dawn and water sparingly. Used compressed air to blow out any water residue. Let it dry overnight. If I killed it I'll let y'all know.
Old May 30, 2017 | 01:49 PM
timski's Avatar
timski
Let us know. Mine is laying on the bench covered in oil and needs to be cleaned.
Old May 30, 2017 | 03:08 PM
sikamini's Avatar
sikamini
It'll be a day or so before I get her to a point where I'll start the engine. I'll post.
Old May 30, 2017 | 03:26 PM
timski's Avatar
timski
Thinking about putting a catch can on the passenger side to hopefully slow down the build-up. Way way too much oil getting to the intake valves.
Old May 30, 2017 | 05:01 PM
sikamini's Avatar
sikamini
If I had a couple hundred to spare I would. I probably will later.
Old Jun 3, 2017 | 11:16 AM
sikamini's Avatar
sikamini
Washing did not hurt it. Yet anyway.
