R55 What part is this
Old May 8, 2017 | 03:30 PM
Hairy W Bush's Avatar
Hairy W Bush
What part is this
this is dripping just a bit. I'm hoping they make a separate gasket for it at the cover.
Old May 8, 2017 | 08:01 PM
timski's Avatar
timski
Vacuum pump. Yep they sell a gasket.
Known problem area.
If you have a lot of miles....just replace the whole pump (sold with gasket).
Old May 9, 2017 | 03:58 AM
Hairy W Bush
I hope I'm wrong, but it looks like the cover is leaking...
Old May 9, 2017 | 06:35 AM
It's here with all the info, the gasket towards the engine is replaceable. The one in the middle of the pump comes with a new pump. Check to see which one is leaking. Then double check the valve cover near the side. Part #11667570813
https://www.northamericanmotoring.co...2009-mini.html
O ring at engine connection. 11667566483
https://www.ecstuning.com/Search/SiteSearch/11667566483/
Old May 9, 2017 | 04:21 PM
Hairy W Bush
it's that part. There's no replaceable gasket at the cover? I'll replace that piece.
Old May 10, 2017 | 05:15 AM
On the valve cover there is a gasket, then the gasket (o-ring 11667566483 above) between the head(near the valve cover) and the vacuum pump.
Here is the valve cover gasket. (NON S ) N12 engine 11127567877
Post # 9
https://www.northamericanmotoring.co...e-missing.html
