Leaking antifreeze
Old May 1, 2017 | 04:40 PM
07YellowMCS's Avatar
07YellowMCS
Leaking antifreeze
Anyone have an idea where this could be coming from?
Old May 1, 2017 | 05:43 PM
07YellowMCS
after looking thru the forums in appears to be the thermostat.
Old May 2, 2017 | 03:18 AM
Scudder44's Avatar
Scudder44
Spot on, your thermostat housing is usually the culprit. Time consuming but easy enough DIY
Old May 2, 2017 | 06:15 PM
Richieb0y28's Avatar
Richieb0y28
yep, mine went last yr. I had to get a shop to do it.
Old May 2, 2017 | 07:04 PM
Cngizbleevng's Avatar
Cngizbleevng
You can get a thermostat housing (contains thermostat) from ECS Tuning for a good price. It's a PITA DIY repair, but it beats paying a shop many hundreds of dollars to do it for you.
Old May 3, 2017 | 06:00 PM
07YellowMCS
Thanks guys. I am going to attempt it. Just waiting for the part
Old May 9, 2017 | 09:02 AM
Thanks for the mention, all the info is here on the DIY:
https://www.northamericanmotoring.co...8-no-heat.html
Old May 13, 2017 | 04:39 PM
07YellowMCS
Any reason why coolant would be coming out of the bleeder screw? It is closed all the way I checked that. Seems like a pin hole and when i turn the screw the direction of the fluid changes.
Old May 15, 2017 | 10:52 AM
Only thing you might have done is stripped out the bleeder screw. Or the gasket/ O-ring is missing. 11537559883 See the little rubber o-ring on the bottom. Check those threads also
https://www.ecstuning.com/Search/SiteSearch/11537559883/
