R55 Just bought a 2009 Clubman...already issues
Old Apr 24, 2017 | 01:36 PM
Hairy W Bush's Avatar
Hairy W Bush
I drove 4 hours on Saturday.The guy persistently claimed it had NO mechanical issues. Well, the passenger airbag light was on and the guy was real pushy and wanted to meet at the gas station. Now I know why.
NEXT DAY the CEL comes on. Took it to Autozone real quick and they printed out a p0015. The Mini dealer says Mini doesn't use a 'P' for their codes and claims if they scan it, it might be something different. They can't give me a loaner until next week and it's my only car. I just got out of a rental.
Either way, this guy's on my ***** list. He's already ignoring my texts.
Old Apr 24, 2017 | 01:48 PM
hello, check out the threads and the part below. That's whats wrong most of the time.
P0015 Cam postion sensor. 13627588095
https://www.northamericanmotoring.co...-bank-1-a.html
https://www.northamericanmotoring.co...-location.html
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Who did your Pre purchase inspection?
Old Apr 24, 2017 | 01:54 PM
Hairy W Bush
thank you I will be reading them now.
One thing I want to add real quick is when I first start it up (cold), I get a little idle surge for about a minute...
Unfortunately there was no time for an inspection. I went with a good friend who had to be at work the next morning, at again an almost 2 hour drive away. Tight situation.
Old Apr 24, 2017 | 01:55 PM
Welcome, could be the sensor or just the engine warming up on start up near 1000 rpm. If it's above that it could be tied to that.
Old Apr 24, 2017 | 02:51 PM
Hairy W Bush
well I went out and pulled out the exhaust cps and it was really dirty. I cleaned it off and the light's still on so I guess I'll order one. I have to ask, can I check the resistance of one of these and see if it's out of spec?
Old Apr 24, 2017 | 02:54 PM
I don't have the ohm spec on these. A scan tool that pulls a code just states it bad and out of spec. So my guess its out of spec.
Old Apr 24, 2017 | 03:01 PM
Hairy W Bush
ok I just ordered it. first time dealing with a CEL so when I replace it, do I leave everything else alone? Don't clear the code right?
Old Apr 26, 2017 | 03:03 PM
Hairy W Bush
I just replaced it and the light is still on.
p.o. does not answer calls or texts. really rustled right now.
Old Apr 26, 2017 | 03:10 PM
DneprDave's Avatar
DneprDave
You have to clear the code with a code reader to make the check engine light turn off.
Some people say you can unhook the battery for a while and that resets the code, but I've always used a code reader to clear codes and have no experience with unhooking the battery to clear them.
Anyone interested in maintaining their own car should have a code reader.
Old Apr 26, 2017 | 03:40 PM
Minnie.the.Moocher
How's the car battery? Did you have it checked? Often times a bad battery will give sensor based errors as the sensor relies on electronic signals to be sent back and forth to computer.
Old Apr 26, 2017 | 04:36 PM
Hairy W Bush
Battery is like new. After going back out 20 minutes later, the light was gone. I took it to Advance anyway. He was able to see the code on his scanner, but it's cleared now and he thinks that should completely solve this problem. Thanks A LOT guys.
Old Apr 26, 2017 | 10:08 PM
Zillon's Avatar
Zillon
I'd strongly suggest getting the car to a dealer or a MINI specialist and have a post-purchase inspection done to prevent any more unexpected anguish.
Old Apr 27, 2017 | 07:20 AM
Hairy W Bush
1 minute into my drive this morning and then light is back on. I haven't had it scanned yet but its probably the same code. What else could this be??
Old Apr 27, 2017 | 07:30 AM
I would have it scanned again and read the code. Also, i would inspect the wires to that plug and the plug itself to the sensor.
Also, try to get ahold of the old owner. But it sounds like you were blown off. You could try to have the MINI dealership pull the MINI service history, but they might not have taken it there once it was out of warranty.
Old Apr 27, 2017 | 04:35 PM
Hairy W Bush
he refuses to answer. I tried calling him today. if anyone wants this jerks # I'd be glad to give it out as a # to avoid.
I had it scanned today and it's the same p0015. connection and wires look fine.
Old Apr 28, 2017 | 07:42 PM
hamptup's Avatar
hamptup
Simply put... Buying a used car is not something you rush out to do without some sort of pre-inspection. You might be shizt out of luck getting ahold of the previous owner. Hopefully the problems you're experiencing is minor and can be resolved quickly.
Old Apr 28, 2017 | 07:43 PM
Hairy W Bush
agreed. but if he wiped out this code completely knowing it would arise again, what was an inspection going to do?
Old Apr 28, 2017 | 10:11 PM
hamptup's Avatar
hamptup
You are right that the code would probably not come up during an inspection but did you even test drive it a bit before you bought it? You mention he met you at some place other than his residence and was real pushy which would draw a red flag in my opinion.
I've bought a handful of used vehicles in my day. Some from private parties and some at a dealership. Been fairly lucky that the cars I've purchased nothing terrible occurred. Buying used is really a crap shoot but if you don't take the time to at the least take it to a reputable shop to check it out and or something doesn't feel right about the car, the seller or the situation you're dealing with I'd pass on the deal.
Old Apr 28, 2017 | 11:17 PM
Scudder44's Avatar
Scudder44
I don't think it is helping if all you have to write about is pre-inspection. The guy needs advice not a reminder of how to buy a used car. He owns it now. Just wish I could assist but I know nothing about error codes.
Old Apr 29, 2017 | 04:04 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
There are two of those sensors in valve cover correct ?
Old Apr 29, 2017 | 06:15 AM
Hairy W Bush
yes I did. it was nowhere near as sluggish as it is now with the light on. just like when I had the light off for that day, it was fine.
yes 1 for intake 1 for exhaust
Old Apr 29, 2017 | 07:23 AM
-=gRaY rAvEn=-
Moderator
Indicates one was replaced.
Ditto.
Was thinking maybe the one replaced was not the one causing the code.
Old Apr 29, 2017 | 07:26 AM
Hairy W Bush
Im not following you. I replaced the exhaust cps...was good for the day, and that's it.
Old Apr 30, 2017 | 09:49 PM
hamptup's Avatar
hamptup
No truer words said!
Best advise is to take it to a reputable mini indy shop instead of thowing parts at it without a proper diagnose tool. My intention wasn't to lecture the kid but I hate when people with good intent get hosed on a deal.
I'm in his corner and I hope Hairy gets it sorted out with minimum grief.
