Mini Cooper S 2008 R56 too many errors
Old Apr 22, 2017 | 07:11 PM
magjistari's Avatar
magjistari
Hi everyone. I havent been driving my mini in a while but problems keep appearing. Check engine was going on randomly now its constant. The only issue that i can tell with the car is when driving at low speeds with low rpm, the car jerks. Its a manual with 50k miles. All errors in the picture attached. I tried sea foaming a few days ago. Couldnt tell any sudden change. Any advice, deeply appreciated.
Attached Thumbnails Mini Cooper S 2008 R56 too many errors-screenshot_20170418-202727.png
Old Apr 23, 2017 | 07:01 PM
gregsmini's Avatar
gregsmini
Margjistari, I'm sorry to hear of your problems. Before getting too far into these codes, how old is the battery in your Mini? I would have it checked out if it's more than a few years old. You also mention you haven't been driving the car. Maybe the battery doesn't have a full charge. When the batteries go bad, they cause strange things to happen in these cars.
Old May 1, 2017 | 05:20 PM
magjistari's Avatar
magjistari
Thank you for your prompt answer Greg. The battery is not old, it was recently replaced, within a year or so. The car starts fine, and runs fine as I was driving it today too. I cleared the codes before i started the trip, drove it maybe for about 20 miles, and like six yellow pending codes came back.
Old May 2, 2017 | 11:25 PM
TimBaleia's Avatar
TimBaleia
Can you read live date with your scanner? Looks like you have lean/rich conditions. Need to see fuel trims. Might be anything from vacuum leaks to O2 sensor or valve cover.
You have pad under the hood which seats over valve cover when hood is closed. Check is this pad soaked with oil? Any oil mist on valve cover?
Old May 3, 2017 | 02:44 PM
imad's Avatar
imad
Could be your throttle body being not adapted . Either pedal sensor is worn, or throttle body is dirty and can't move to the position it should stay at, causing rich/lean states. Low rpm jerking is expected when running rich - your sparks must be quite wet (you could confirm this btw).
I would say throttle body worth checking first. If you have rheingold, you could see it's position (both requested and actual), as well as pedal position. Any fluctuations without your foot touching the pedal would mean you need to dig into these two.
Of course you need to be sure there's no pressure/vacuum leak before you go to the rest.
Old May 4, 2017 | 06:31 AM
magjistari's Avatar
magjistari
Hi everyone, Thank you for your input. I did open the throttle as that's where is first suspected, however, it was pretty darn clean. Sorry I didn't take pictures. I did wipe it clean, moved the flapper by hand, pretty smooth. I will definitely check with rheingold later in the week as I don't think torque for mobile showed those values. Will definitely update asap.
Old Jun 13, 2017 | 10:45 AM
magjistari's Avatar
magjistari
Hi everyone, recent updates. As i got rid of my daily car ive been driving the mini. Errors seem to be disappearing on its own. Once in a while i get these two errors, and ive noticed that when errors are active the turbine doesnt engage.
Old Jun 13, 2017 | 11:41 AM
sikamini's Avatar
sikamini
Drive more I guess.
Old Jun 13, 2017 | 09:30 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
P0120 and P0121 indicate a problem with the accelerator/throttle pedal. There are two sensing circuits for redundancy, one isn't working. Could be the the pedal assembly itself, a loose connector, or the wiring to the ECU. Check the connector at the pedal and at the ECU, also as much of the wiring as possible. You may have to replace the pedal assembly.
Old Jun 14, 2017 | 05:53 PM
bugeye1031's Avatar
bugeye1031
Moderator
Off the wall thought
Is your battery from MINI or aftermarket? I had a newish/strong aftermarket battery from a well-known brand and had several codes come up randomly, and my clock and odometer would reset occasionally. The battery had been properly registered. I just lived with it until my mechanic had time to dig into it. He found that one of the terminals (positive, I think) on the aftermarket battery was slightly smaller that the OEM battery, so the connection wasn't perfect. He replaced the battery and did nothing else, and no more codes.
Old Jun 16, 2017 | 12:05 PM
^^ my guess also is that the terminal are not tight on the battery.
Old Jul 25, 2017 | 02:15 PM
magjistari's Avatar
magjistari
So i did replace the pedal assembly with no change. Now the car keeps going limp randomly. I have to stop, reset the codes, and back online. With torque app i notice that when the car is like in a limp mode, the throttle does not respond to the pedal being pressed, while rpm goes to almost 2500. Vacuum seems to respond. Please see the pic. Battery terminals seem to be tight and battery is in good shape. Havent had an issue with it.
Attached Thumbnails Mini Cooper S 2008 R56 too many errors-screenshot_20170724-232311.png
Old Jul 31, 2017 | 07:24 PM
magjistari's Avatar
magjistari
So I went ahead and got a used throttle from ebay for about 85 bucks and problem solved. Apparently the issue was the throttle body sensor. Car runs perfect. I just have to take it to mini of Austin as apparently it has warranty upto 120k for high pressure fuel pump and passenger seat airbag mat. Im not noticing any issues for the fuel pump but the passenger airbag light is on. And I will check if they can reset my brake light and tpms light too. I tried resetting the brake light according to youtube videos, but its not doing it for me. Thank you everyone for your contribution.
Old Jul 31, 2017 | 10:54 PM
imad's Avatar
imad
Happy to see it's fixed
Old Aug 2, 2017 | 11:53 AM
cargusjoh's Avatar
cargusjoh
Thanks for posting the solution for others to reference!
