R50/53 Always things to learn about my R53
Old Apr 18, 2017 | 11:38 AM
175HP's Avatar
175HP
It has been a long time since I posted last. I sent my R53 to Bmw to have frame work and suspension redone. Car handles so much better, I also found the source of my engine squeak, the serpentine belt, I bought an OEM belt and the sound is gone. I am hearing a loud squealing sound when accelerating hard, I am guessing my belt is slipping. Is there anything I can do to minimize or eliminate the slipping. I would think I could get a quicker acceleration without the slipping.
Also does anyone know how to program a new key?
Old Apr 18, 2017 | 11:51 AM
RB-MINI's Avatar
RB-MINI
What kind of frame and suspension work, and are you sure you have a stock pulley on the supercharger? The BMW dealer probably put on a stock belt, but the JCW and aftermarket pullies need a smaller belt.
Also, the belt tensioners don't seem to last so maybe a new tensioner is needed. Most of the time the small shock/damper is worn out, but they don't seem to be available separately.
Old Apr 18, 2017 | 12:23 PM
175HP's Avatar
175HP
As in frame work it included included some really small things, not like a cracked or bent frame. I have replaced the tensioner multiple times as it isn't causing any trouble. It might be the pulley which I am planning on doing a reduction anyways.
Old Apr 25, 2017 | 06:38 AM
X757XVeritas's Avatar
X757XVeritas
What small things can be done to a frame, if its not rusted or bent there really isnt any frame work that can be done.
Old Apr 25, 2017 | 08:18 AM
rkw's Avatar
rkw
For a 2003, needs to be programmed by the dealer (or independent shop with the necessary software).
Old Apr 25, 2017 | 09:02 AM
175HP's Avatar
175HP
ok, frame wasn't touched but components mounted onto the frame were fixed or replaced.
Old Apr 26, 2017 | 01:24 PM
Nice white R91's wheels. Keys need to be done at the dealership, some indies have it.
Old Apr 27, 2017 | 01:51 PM
ZippyNH's Avatar
ZippyNH
Bet you have a reduction pulley...
So the OEM belt is too long...
Slipping at higher rpms... causing noise. Can also cause loss of HP, and can get tossed off, resulting in a tow and about $1000+ in parts. They did you no favor putting an OEM belt on.
Fix...shorter aftermarket belt.
And please note
The MINI is a UNIBODY...so NO FRAME. just saying.
Old May 3, 2017 | 12:08 PM
175HP's Avatar
175HP
Used to some classic American muscle, why I keep saying frame
Old May 3, 2017 | 02:37 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
I would think that a slipping belt should throw a code, even go into limp mode if severe. Perhaps you have an idler pulley going bad?
Old May 5, 2017 | 09:41 PM
ItsmeWayne's Avatar
ItsmeWayne
I think either the belt is too long, or the belt tensioner is going bad.
