Suspension How low can I go?
Old Sep 29, 2004 | 02:23 PM
kyriian's Avatar
kyriian
How low can I go?
I was wondering if any expert can tell me how low can I drop my car without serious rubbing, im currently trying to find a good coil setup and want to know exactly how low can I go (if i can't use most of the height range then forget it)
i run on a set of very square bridgestone re750 215/45-17 on a set of motegi ff6 wheels with offset at 42mm
thanks in advance... currently finding out if it's possible to get a set of used pss9s, or new tein type ss coil, and been thinking about the h&r rss...
-kyriian
Old Sep 29, 2004 | 03:00 PM
erik808's Avatar
erik808
Moderation, son... moderation:smile:
Peace
Old Sep 29, 2004 | 03:10 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
-kyriian
There is an MCS in my area that used coil overs and dropped it to the max. The fenders were sitting on the tires and the owner didn't think he could drive it out on the road so he had it raised a bit more. It think the drop was about 1.5 inches or maybe a little more. Coil overs are adjustable so you can get more fine tuning than you can with lowering springs. The max drop you could get with springs probably will be from HR springs, about 40mm.
I have H-sport springs with 1" drop front and rear and square shouldered Yokohama ES100 tires in 215/45-17 and I get rubbing with four people but not with two people.
My wheels are 17x7" with offset of +42mm.
Old Sep 29, 2004 | 08:20 PM
kyriian's Avatar
kyriian
thanks for the help guys
im not so worried about getting too low, i have no options (so no sunroof) so i think it places the coils slightly higher (dont know where i read that)
what's the drop range for the pss9 anyways... i know tein drops at least 1 inch to about 2 inches... h&r rss is similar as well
also, dropping is one thing, all i need to do really is to trim the inside plastic well if it rubs too badly
Old Sep 29, 2004 | 08:44 PM
El Diablito Rojo-N20Mini's Avatar
I have Leda's and it's low.....going to raise it some.... I feel like LOW---RIDER
debitsandcredits
Sep 21, 2015 08:34 AM
OdzBodkinz
Sep 11, 2015 07:20 PM
Sep 10, 2015 11:55 AM
kjd186
Sep 9, 2015 10:02 AM
