Spending one quart of oil per month
Old Apr 10, 2017 | 04:22 AM
enatal's Avatar
enatal
Hello.
My 2011 Clubman is asking for one quart of oil every month. I have not seen oil leaks in the garage floor. The BMW/MINI service center has not found oil leaks or pressure issues. So far they have found a faulty water pump. The sevice advisor says that MINIs burn oil, but I do not buy that. Is there anything else that can cause this?
Please advise
Thanks.
Old Apr 10, 2017 | 04:36 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
oil separator could be faulty
Old Apr 10, 2017 | 05:34 AM
enatal's Avatar
enatal
Oil separator works fine
Old Apr 10, 2017 | 05:59 AM
MrBlah's Avatar
MrBlah
how did you check? The oil is either going in the separator or the turbo seal is leaking
these run positive vacuum so even with bad rings they really dont burn that way
Old Apr 10, 2017 | 08:12 AM
enatal's Avatar
enatal
They made pressure checks with no leaks
Old Apr 10, 2017 | 08:13 AM
enatal's Avatar
enatal
The vehicle is not S series. No turbocharger
Old Apr 10, 2017 | 09:09 AM
MrBlah's Avatar
MrBlah
well that makes it easy, it's the ccv crap, pretty common fault bmw does not care if you are less than 1 quart every 1000 miles or something absurd like that
Old Apr 10, 2017 | 09:22 AM
enatal's Avatar
enatal
What is the CCV?, they already checked it.
Old Apr 10, 2017 | 10:13 AM
MrBlah's Avatar
MrBlah
take it to an indy mechanic if you dont know what a ccv is
Old Apr 10, 2017 | 11:32 AM
enatal's Avatar
enatal
Yes, they checked the Crankcase Ventilation Filter.
Old Apr 11, 2017 | 12:24 PM
mikeyb74's Avatar
mikeyb74
Which engine does the Clubman have? What do you drive for mileage? It is common thing for BMWs and MINIs to burn oil. My BMW 135is burns altleast a quart a month.
The crankcase vent valve is built into the plastic head cover. I had to replace the cover due to it being both cracked and the CCV being faulty.
BMW/MINI has bulletins regarding burning oil. It is a quart at 1000 miles that is normal.
Old Apr 11, 2017 | 01:31 PM
MrBlah's Avatar
MrBlah
It's not normal they just don't want to fix it, none of my 20+ BMWs burned any oil including my 135i I bought new in 08 and sold a week ago
My 540i and one of the minth started to burn oil, both were ccv issues
Old Apr 11, 2017 | 03:44 PM
enatal's Avatar
enatal
The car has 64000 miles.
Old Apr 11, 2017 | 05:58 PM
05r50's Avatar
05r50
It's not a BMW engine. It is a Peugeot N16 motor on the R55 from 2011. The R56 N14 Peugeots motors have had a lot of oil consumption stories. MINI does state that consumption is reasonable and expected based on the manual.
You will be beating a dead horse with a MINI dealer.
Old Apr 11, 2017 | 06:00 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Originally Posted by enatal
Hello.
Please advise
Thanks.
You have the newer engine and non S and yet still burning 1qt in less than 1000 miles ?
What viscosity are you using ?
What was your oil change frequency ?
Old Apr 12, 2017 | 04:46 AM
MrBlah's Avatar
MrBlah
does not matter, it's a ccv problem or a massive O ring leak somewhere but that would show up on the ground
Old Apr 12, 2017 | 05:37 AM
Yes, N16 should not burn too much oil at all. I would check for an oil leak first. Maybe a sticky CCV in the valve cover?
Old Apr 25, 2017 | 04:54 AM
enatal's Avatar
enatal
Hello
The MINI service center replaced the gasket of the cylinder head cover. Got the car back after almost three weeks in the shop.
Old Apr 25, 2017 | 05:02 AM
enatal's Avatar
enatal
Thanks to all who responded this thread. Your responses were very helpful.
Old Apr 25, 2017 | 05:42 AM
MrBlah's Avatar
MrBlah
that fixed it?
Old Apr 26, 2017 | 05:28 AM
enatal's Avatar
enatal
Result
It was fixed Last Thursday (Apr 18, 2017). I will check one month from now if tge car asks for an oil quart.
Old Aug 15, 2017 | 11:54 AM
TorchMINI's Avatar
TorchMINI
I'm curious for a summary and a followup. My Mini has the N12 engine, now with over 100,000 miles, but has been using 1 quart per 700 miles since about 65,000 mi on the odometer.
I have no leaks nor see any blue smoke, so I am trying to follow the stories about the PCV valve in the valve cover. Anyone fixed their oil consumption by fixing/replacing the valve cover?
What is the long term effect on an engine of driving with a plugged PCV?
Old Aug 15, 2017 | 12:17 PM
enatal's Avatar
enatal
Fixed!
After replacing the PCV and the valve cover gaskets. the car has not requested to add oil.
Old Aug 15, 2017 | 12:18 PM
enatal's Avatar
enatal
Fixed!
Correction: it was the CCV (crankcase control valve) not the PCV.
