Hello, I'm working on my 2003 Mini Cooper S and I'm stuck on the replacing my rear calipers. How do I remove the rear brake line as well as the emergency brake line going to the caliper?
The lines you will need correct size wrench to fit the line and pop it off. make sure you cap the old line to not let air in and then after you done and its attached. Bleed the line.
