2009 Clubman S Auto stalled and will not start
I was on the freeway cruising along and all of sudden my clubman stalled. I pulled on the side and try to start without any luck. Towed the vehicle home suspecting the timing chain. After a compression test all cylinders were @ 160psi so I eliminated the timing chain. Checked for spark while cranking the engine and that was just fine. Checked for power to the fuel pump and non was present. I jumped the fuel pump and it was working. The fuel pump fuse is good. Any help will greatly appreciated. I checked most posts and it appears that nobody had the problem that I'm having. The one thing that I did not check was the fuel pump relay as I have no idea where to look for it.
