2009 Clubman S Auto stalled and will not start
Old Mar 18, 2017 | 04:59 PM
tanastas's Avatar
tanastas
I was on the freeway cruising along and all of sudden my clubman stalled. I pulled on the side and try to start without any luck. Towed the vehicle home suspecting the timing chain. After a compression test all cylinders were @ 160psi so I eliminated the timing chain. Checked for spark while cranking the engine and that was just fine. Checked for power to the fuel pump and non was present. I jumped the fuel pump and it was working. The fuel pump fuse is good. Any help will greatly appreciated. I checked most posts and it appears that nobody had the problem that I'm having. The one thing that I did not check was the fuel pump relay as I have no idea where to look for it.
Old Mar 19, 2017 | 06:01 PM
tanastas's Avatar
tanastas
Ok here is an update. I can confirm that the fuel pump is getting power and I can hear it cycling. Is there anything else that I should check before I tow it to the dealer?
Old Mar 19, 2017 | 06:40 PM
AZdsrt's Avatar
AZdsrt
Is there a CEL? Since it died and won't start, there should be one. Knowing what the CEL code is about the only way to start troubleshooting..
Old Mar 22, 2017 | 10:43 AM
tanastas's Avatar
tanastas
I spoke with the dealer this morning and they are suspecting the HPFP. I was told that it's still under warranty so.... on the way to the dealer.
