FS:: 2016 Countryman Hitch System- bolt on
Old Mar 12, 2017 | 11:04 PM
stevedds's Avatar
stevedds
Category: Exterior
Price: $200
I used this hitch on my 2016 Countrymanfor 2 years for light towing .. worked flawlessly. Good condition.
Countryman/Paceman “No Cut, No Drill” Accessory Hitch
Our CooperCrap hitch is rated for 200lbs of tongue weight and 1,000 lbs for towing. We use the larger 2” receiver style for more options. We have tested our hitches vigorously on and off-road to determine the safety, functionality and durability of our product.
We make our own custom threaded posts which install into the the frame, you slide the hitch over them and install the Grade 8 bolts. When not in use you can easily remove it and pop the plugs back into the bumper and there are no telltale signs a trailer hitch has been installed.
Old Apr 25, 2017 | 06:28 PM
Carlo Recio's Avatar
Carlo Recio
Tow Hitch
PM sent.
Old Feb 24, 2021 | 05:00 PM
OldGuyToo's Avatar
OldGuyToo
Hitch
Do you make a hitch for a 2016 4 door Mini?
QUOTE=stevedds;4287049]I used this hitch on my 2016 Countrymanfor 2 years for light towing .. worked flawlessly. Good condition.
We make our own custom threaded posts which install into the the frame, you slide the hitch over them and install the Grade 8 bolts. When not in use you can easily remove it and pop the plugs back into the bumper and there are no telltale signs a trailer hitch has been installed.[/QUOTE]
Alternative
F54 :: Clubman Talk (2015+)
16
May 14, 2025 08:59 PM
ukan16
Jan 21, 2015 04:02 PM
kunzman
Jan 21, 2013 10:16 PM
darkus
27
May 24, 2012 06:38 PM
putttn
23
Jun 6, 2008 11:13 PM
