R55 Cel codes
Old Mar 9, 2017 | 12:03 PM
Michael Brewer's Avatar
Michael Brewer
Cel codes
I have a 2008 clubman s I just had a valve job done put everything back together and now im getting two codes one is a 2f1a and the other is a 2f19 which according to what I did fine it had something to do with my temp sensor but I can read engine temp on my modus scanner so any help would be appreciated
Old Apr 4, 2017 | 10:02 AM
MiniToBe's Avatar
MiniToBe
you can read temp, but you dont know for sure if it the correct temp...make sure you let the bubbles out of the cooling system. there is also a breather next to the temp sensor, open it a little till the coolant flows out. finally, you might have a faulty thermostat unit!
Old Apr 7, 2017 | 12:02 PM
Yea, might be the thermostat, Check the connection plug on the top of the thermostat housing first.
https://www.northamericanmotoring.co...8-no-heat.html
Brown sensor. 11537534521 KT
Old Apr 10, 2017 | 09:35 AM
danraabe's Avatar
danraabe
My check engine light comes on when the outside temp goes above 70 degrees F. It was fine all winter but we had a hot day yesterday and it lit up the dash board. The last time i had it cleared the code seemed to point to a fuel system fault. Any experience with that issue?
Old Apr 10, 2017 | 10:09 AM
MiniToBe's Avatar
MiniToBe
what is the code?
Old Apr 10, 2017 | 10:23 AM
danraabe's Avatar
danraabe
Cel
I'll post it a little later if that's okay. There is a shop close to me here that can read the code. I don't have an ODB tool.
Old Apr 10, 2017 | 02:05 PM
danraabe's Avatar
danraabe
Cel
I took the car to a repair shop and interestingly they told me there were no error codes. They did say that there were 3 systems on a list of 10 that were not in a ready state.
i couldn't get the codes. Do I take it back and let them put the thing on a more precision machine or do I take it to Mini and ask them to read the codes?
Dan Raabe
Old Apr 10, 2017 | 02:24 PM
MiniToBe's Avatar
MiniToBe
Let autozone check it for you. Clear it and see if it pops again. Mine did the same few weeks ago and said o2 sonsor. I cleared it and nothing back so far!!!
