n18 noises
Old Mar 8, 2017 | 09:21 AM
one73ronin's Avatar
one73ronin
n18 noises
i have a 2013 cms all4 with 42k miles. i bought it a couple of months ago and the engine has always sounded like a diesel motor. i asked the question in another thread about how it could be the turbo going out, but he suggested the timing chain tensioner? does that mean the plastic arms or the tensioner (bolt looking thing ) itself. i thought this problem was figured out with this year, thats why i bought it and not an 11' or 12'
here are a few videos to illustrate...
n18 cold
n18 warm
Old Mar 8, 2017 | 10:27 AM
cerenkov's Avatar
cerenkov
Direct injected engines are noisy. Too me this sounds normal.
The tensioner is the bolt looking device. I believe that the plastic arms that you mention are the chain guides.
Old Mar 8, 2017 | 10:36 AM
cstrumol's Avatar
cstrumol
Sounds just like mine, don't think there is anything glaring wrong. Timing chain is very loud and noticeable. Many say it sounds like rocks being kicked around in the engine. If no codes, just check your fluids.
Old Mar 8, 2017 | 10:55 AM
one73ronin's Avatar
one73ronin
thats quite a relief, but im still paranoid...my r53 has made me this way....
fluids are fine.
now for a bigger turbo and tune!
Old Mar 8, 2017 | 11:08 AM
Sall4Ken's Avatar
Sall4Ken
Yep mine sounds the same you can usually hear the tensioner rattle independent of the engine noise its kind of an off cadence sound. If it was the turbo you usually hear a whine or if the seals crack or burn excessive smoke. I think you are fine i thought something was a bit wrong with mine as well initially until i stood by several other countryman and heard the same loud noises.
Old Mar 10, 2017 | 10:51 AM
one73ronin's Avatar
one73ronin
i need to find another local cms owner and compare noises, plus maybemake a new friend!
what about the high pitch noise when i turn the car off? i can kinda hear it in the cab but more prominent when i get out of the car. i am guessing its a transmission cooler fan or power steering fan that runs for a little while after turning the car off, but its winter time so i find it odd. i dont drive very far to work and back, maybe 6 miles...
Old Mar 10, 2017 | 11:59 AM
cerenkov's Avatar
cerenkov
The auxiliary water pump runs for a while after shutdown to cool the turbo.
Old Mar 12, 2017 | 01:47 PM
one73ronin's Avatar
one73ronin
is it shocks or swaybars that helps with body roll?
Old Mar 27, 2017 | 05:06 PM
one73ronin's Avatar
one73ronin
so im paranoid, and talking to someone else, i decided i will change the timing change tensioner, where would i find a guide on how to change it?
when i search here all i get is tensioner issues, not how to change
any help is appreciated.
Old Mar 28, 2017 | 05:19 AM
MiniToBe's Avatar
MiniToBe
N18 engine is not known to have that issue with the tensioner. just make sure you have oil and the correct weight/viscosity (5W30).
Replacing the tensioner is not as simple as unscrew and screw a new one! remember that the intake and exhaust sprockets might be under internal tension. Once you release the tension, you will throw it out of timing.
Old Mar 28, 2017 | 08:59 AM
ProjectMini's Avatar
ProjectMini
Can confirm My R60 Is "Loud Diesel sounding"
The tensioner will leave you no doubt to what it is.
The new 2017 I am driving also sounds the same to be honest they have done a much better job an insulating the cabin so its not as nosiey from the inside even with windows down. Go test drive a new one to confirm if you have a day and a MINI dealer near you.
Old Mar 28, 2017 | 09:24 AM
one73ronin's Avatar
one73ronin
good advise Minitobe, now im super paranoid.....maybe i should just get the oil changed first.
ProjectMini, the closest mini dealer is in reno, 4hrs, i did find someone else in town that has a countryman, and with a side to side comparo mine was louder by far.
Old Apr 4, 2017 | 10:12 PM
MannyJimenez's Avatar
MannyJimenez
My 2011 MCCMs (R60s) ALL4 only gets loud when the oil level is low (about a quart low), that's the only time my engine gets noisy. Top off the oil and it gets quieter, but not quiet, it pretty much sounds like the videos you posted when all the fluids are at optimum levels.
Old Apr 6, 2017 | 09:24 PM
one73ronin's Avatar
one73ronin
I did add oil, enough to show too much on the dipstick, and while quieter, its still pretty loud on cold starts. its just disconcerting to me, its as loud or louder than my daughter's 08 TDI.
im looking forward to modding this, but I want to make sure its close to 100% before I dive in.
my wife giggles whenever I get concerns...I don't think its funny.
Old Apr 7, 2017 | 06:11 PM
Andrew13's Avatar
Andrew13
I am also concerned i just bought a 2012 r60 s all4 with 85000 km and it sounds like yours
Old Apr 7, 2017 | 06:59 PM
one73ronin's Avatar
one73ronin
my advice, find another cms owner nearby or on the forum and do a side to side comparison, that my help...
so I'm just going to have to put everything off until I can get the timing chain replaced or a code shows up. its a tad bit frustrating
Old Apr 12, 2017 | 05:55 AM
JoeJoe71's Avatar
JoeJoe71
Just installed M7 CAI with silicone intercooler charge pipe. Now when I start engine it makes a whooshing sound for a while then stops. It doesn't do it every time. Any ideas? Is it BOV?
Old Apr 12, 2017 | 07:40 AM
MiniToBe's Avatar
MiniToBe
Mine does the same with the whooshing and i love it
Old Apr 14, 2017 | 11:51 AM
iwashmycar's Avatar
iwashmycar
Ours sounds that way too.
Old Apr 14, 2017 | 12:48 PM
MannyJimenez
Here's mine at 55k miles
Old Apr 14, 2017 | 06:21 PM
randeez's Avatar
randeez
OP sounds fine to me, i wish mine was that quiet when warm lol
mine sounds like manny's until i put the slightest bit of pressure on the heat shield then it all goes away and sounds fine
Old Apr 15, 2017 | 01:54 PM
one73ronin's Avatar
one73ronin
thanks Manny, thats quite helpful, calms my brain. im going to san fran in early may, if the mini comes back unscathed, the mod game begins!!!!!
Old Apr 17, 2017 | 06:54 AM
MannyJimenez
