Oops, tire rubbing . . .
Old Sep 25, 2004 | 12:50 PM
Hammer's Avatar
Hammer
I swapped out my 17" S-Lites (for sale, by the way!!!) for some 17" Konigs. I put a set of Faulken Azenis 225/45/17 on. Per Tirerack and other sites it didn't appear to be a fitment issue. But now I've noticed they are rubbing. But not on the inside, on the top! It seems the tire is too tall!? There appears to be wheel well clearance, but the suspension must be softer than I thought and must be rubbing when I hit bumps. Anyone else have this tire set up? Any issues?
Old Sep 26, 2004 | 03:33 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Sorry, whenever I talk to alex@tirerack and ask about 225/45-17 tires he tells me that I will need to do some wheel well trimming.
You have stock suspension or aftermarket suspension?
What wheel offset do you have?
For the MINI there are Falken Azenis Sport tires that will fit 15" and 16" rims but not for 17" without rubbing when I have looked.
Old Sep 26, 2004 | 04:26 AM
Hammer's Avatar
Hammer
I was using the Tirerack website. I popped in Mini Cooper S, then the custom tire size. I assumed if there was a fitment issue that the website would start blarring some warning at me - you know, flashing lights, sirens, etc. When I ordered my Hoosiers in the same size and told them they would be going on a Mini they didn't mention a fitment issue. It doesn't seem to be rubbing too badly, so I guess I'll just live with it. If it becomes a safety issue I'll have to do something about it. I'm running the stock S Sport Package suspension.
Old Sep 26, 2004 | 10:27 AM
Mini-///M's Avatar
Mini-///M
Falken Azenis' run BIG. Those tires are more like 235/45's maybe even bigger.
Patrick
Old Oct 2, 2004 | 10:18 AM
Hammer's Avatar
Hammer
Patrick
Ah. Here's a pic, it's not rubbing badly.
Old Oct 2, 2004 | 11:22 AM
minihune's Avatar
minihune
Rubbing? Two places to check for wear.
Sometimes the tire isn't showing quite so much rubbing as the wheel well.
For wear you can check the rear wheel well on the 10 o'clock position on the right rear and 2 o'clock position on the left rear. Mine is ground up with pieces of hard plastic worn off. Naturally these are the places to trim with a dremmel tool to eliminate the rubbing.
My tire was not worn much. Since then my solo II driving has helped to round off those square tire shoulders and I think that has helped. I never did get around to do the trimming.
Old Oct 3, 2004 | 03:14 AM
d6-mcs's Avatar
d6-mcs
you call the rubbing bad. my god you should see my tires. i have grand canyon on the rear tires. dam 215/40/17 on a 17x9 but its worst it
chris
Old Oct 3, 2004 | 03:08 PM
DancesWithCones's Avatar
DancesWithCones
I was using the Tirerack website. I popped in Mini Cooper S, then the custom tire size. I assumed if there was a fitment issue that the website would start blarring some warning at me - you know, flashing lights, sirens, etc. ...
For what it's worth, you will not see 225-anything in the "recommended" section of their website. When you went to the custom size entry, you left the recommendations. The TireRack assume you know what you're doing if you're clicking the drop-down list. As it stands, you got neither the tires nor the wheels from them. If you worked with Alex at TireRack, you would have been told that rubbing would be very likely. As it is, Tire Rack had nothing to do with your purchase so don't attribute your mistake with them.
Old Oct 3, 2004 | 05:25 PM
Hammer's Avatar
Hammer
Whoa, lighten up a little. I didn't attribute anything to tirerack, and if you read my post the way it was written (flashing lights, sirens) you would clearly see I was speaking in jest. No big deal, I'm not bashing tirerack. Heck, the post is even entitled "Oops", thereby signifying my own mistake. Wow, I didn't mean to strike a nerve. Besides, 5 minutes with a dremel solved the problem.
Old Nov 17, 2004 | 12:05 PM
MyPocketRocket's Avatar
MyPocketRocket
would you like to show how you did fix it? ..pictures?
Supertractor3
Apr 7, 2017 11:16 AM
dpike
Sep 12, 2015 08:19 AM
makg
Sep 10, 2015 11:59 AM
Ntety
Sep 2, 2015 08:39 PM
