R50/53 Help me identify this pulley
Old Jan 30, 2017 | 08:52 AM
kyleroot's Avatar
kyleroot
I bought this car used, and it has a pulley I am trying to figure out who makes it and what % it is.
Thanks for any and all help.
Old Jan 31, 2017 | 04:54 AM
IQRaceworks's Avatar
IQRaceworks
The only way to be sure is to take it off. Can you get a mirror down in there and see if there are any markings on the pulley? Do you have a boost gauge? If so.....how many pounds of boost is the motor making?
Old Jan 31, 2017 | 05:48 AM
kyleroot's Avatar
kyleroot
I do have a boost gauge I run about 14.5-15psi
Old Jan 31, 2017 | 05:56 AM
IQRaceworks
Its probably a 15% pulley then.
Old Jan 31, 2017 | 06:15 AM
kyleroot's Avatar
kyleroot
Perfect, Thank you!
Old Jan 31, 2017 | 12:30 PM
gumbedamit's Avatar
gumbedamit
Where are you located. seems like a lot of rust on your car. Make sure you get tons of penetrating oil and lube everything up before you start taking it apart.
Old Jan 31, 2017 | 12:31 PM
kyleroot's Avatar
kyleroot
Car is from Jersey, I live in Buffalo. This is not a lot of rust in Buffalo... but yeah you're right.
Old Jan 31, 2017 | 01:58 PM
Whine not Walnuts's Avatar
Whine not Walnuts
And heat the screws up as they most likely have locktite
Old Jan 31, 2017 | 08:07 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
That's an old Helix pulley. Looks like a 15% with the bolt spacing, and they are the most popular. I wouldn't worry about the rust on the screws at it's just surface rust.
Old Feb 17, 2017 | 09:38 AM
kyleroot's Avatar
kyleroot
Thanks for the help everyone
