R50/53 NEED HELP! Locked out of my car!
Old Jan 29, 2017 | 06:10 PM
chicolean83's Avatar
chicolean83
Hello fellow Mini People. I did a very dumb thing to say the least. I have managed to lock myself out the car while the battery is disconnected. I also left the car keys in the trunk and do not have a spare
Just had a locksmith come but he was unable to open the door. I do not want to have to break the window but i dont know any other options. Can any one please help.
Old Jan 29, 2017 | 06:56 PM
Racingguy04's Avatar
Racingguy04
I would try another locksmith. Or a slim jim. There's a cable that runs from the interior door **** to the latch, if you can snag that with the slim jim, that would open the door. The other way would be to pry the window back from the door frame and get in there with some sort of tool/hook that the locksmith could manipulate the door handle with and open the door.
Worst case scenario, if you do end up having to break glass, you might find out what's cheapest to replace before you do it. I'm betting it's the glass that's between the window and the rear door, or if you're in the market for a new windshield, now might be a good time to have one of those guys come and replace your windshield, you could always unlock the front doors while your windshield is out.
Old Jan 29, 2017 | 07:27 PM
chicolean83
I had two locksmith come through AAA. They did try to pull the door **** latch and it did not budge. I might have to try another locksmith. Thank you for the response.
Old Jan 30, 2017 | 05:24 AM
gjxj's Avatar
gjxj
maybe see if a dealer can cut you a new key
(probably cost more than a new window though)
Old Jan 30, 2017 | 11:06 AM
X757XVeritas's Avatar
X757XVeritas
Sounds like he could benefit from a spare key anyway though.
Old Jan 30, 2017 | 12:15 PM
coopermike29's Avatar
coopermike29
GO to dealer and order a key. They will have it in ONE day.
You'll need your proof of ownership.
Trust me......you will not regret it
Old Feb 1, 2017 | 07:40 AM
valvashon's Avatar
valvashon
Since you need a spare anyway I would recommend getting what is called the "general, non-remote" key. Cheaper and has a blade for the door and the EWS chip to allow your car to start. If your door locks and actuators are in proper order you should be able to open the door with the blade even though the battery is disconnected.
Breaking the window will be just a big mess and you need a second key anyway. The non-remote key will be around $100; money well spent. They are available for both the clamshell two button style of key and the flat three button keys.
Let us know how this turns out.
Bruce
Old Feb 1, 2017 | 09:38 AM
Andrew Riley's Avatar
Andrew Riley
+1 on the new "valet key".
If the dealer is too far, mine is 2 hours.
You could always use a shimmy with a hook to catch the door handle on the inside. It's possible. I've broken into my MINI before. Don't worry, just take your time. IIRC I used a hanger type of material, thicker and bent a hook. Used a large flathead to pry the glass/gasket out of the way.
It is possible.
Good luck.
Old Nov 12, 2019 | 05:34 AM
MadisonJessica's Avatar
MadisonJessica
If 24 hr locksmith from AAA can't be able to unlock the latch then taking help from the dealer is the only option left behind.
Old Nov 15, 2019 | 08:36 AM
MVPeters's Avatar
MVPeters
3 days later.........
If the car is still locked, try this, though it's not easy:
Under the front of the car, with a long screwdriver/pry bar, release the hood catches. The left side is not easy to get to, but it is possible. You need a second person to hold the hood up to prevent it re-engaging.
Then put jumper cables on the under-hood terminal & ground. Hopefully, the car is not actually 'locked'.
I'm not entirely certain, but I think the door catches & locks rely on electricty to operate - ie there is no 'mechanical' way in.
Old Nov 15, 2019 | 10:31 AM
Andy_S's Avatar
Andy_S
Almost three years later! What appears to be a spammer popped the thread back from the past.
Old Nov 15, 2019 | 10:44 AM
MVPeters's Avatar
MVPeters
Well, oops, sorry, the previous post was on 11-12-2019........
I wonder how the OP got the car unlocked?
