BlueDriver OBD Scanner Not Clearing
Old Jan 27, 2017 | 01:05 PM
Greyman's Avatar
Greyman
Hey everyone!
Anyone else using a Bluedriver OBD scanner on their mini? I just got one for my 10' JCW because of a CEL I keep throwing. Wanted to know what the problem was before I took it to the doctor, that worked just fine, but every time I try to clear the code it tells me it can't with the engine running. Turn the engine off though and try again, now it tells me it's no longer connected to a vehicle.
annoying...
Any ideas?
Old Jan 27, 2017 | 07:21 PM
JimR56JCW's Avatar
JimR56JCW
I have a Bluedriver. I had this problem a couple times. If I remember right I had to relaunch App to reconnect to vehicle. It's been a while so I can't say for sure. I will connect mine tomorrow and see what happens.
Old Jan 28, 2017 | 05:41 AM
BlueDriver's Avatar
BlueDriver
Hello! (here's to google alerts!)
A number of BMW vehicles require the engine off and ignition in the run position to clear codes (a few also require the driver side door to be open for some reason, but I don't think that applies to Minis).
If you have keyless start, you can start your ignition by pressing the start button without your foot on the brake - you want the dash lit up with the CEL active, cabin fans on, etc before you try to connect. You might also want to unplug your BlueDriver and plug it back in after starting your ignition just to make sure there isn't a sleep mode issue at play (the device uses the voltage increase from the alternator to detect a running engine).
If you have any questions let me know! You can also contact us through the app by going to "more", "contact us", and "email"!
Old Jan 28, 2017 | 01:57 PM
JimR56JCW's Avatar
JimR56JCW
I just used my bluedriver. It connected after I started engine. I scanned for codes and then cleared all codes without a problem.
Old Jan 30, 2017 | 07:25 AM
Greyman's Avatar
Greyman
Awesome!
Thanks for the response guys, I will give it a try. I didn't think I would need to be that specific when using it, but no worries.
Thank you for the details "Bluedriver", I will keep you posted and use your suggestion if I have anymore problems. Comforting to know support for you product is so aware.
