R57 Yellow engine light and engine missing
Old Jan 21, 2017 | 08:03 AM
mrbug's Avatar
mrbug
I got a yellow engine light so I took it to check the code. Code came back with 3 & 4 cylinder miss firing. I pulled those two plugs this morning. #3 looked like it had been dipped in oil. Oil was literally running off of it. #4 did not look bad but was not drinched in oil. I am going to clean the plug since no one carries plugs for it and move the 3&4 coil packs to 1&2 to see if the missing will follow the coils and try to get the oil out of cylinder 3. Can I reset the yellow check engine light and if so how? The car is just shy of 100,000 miles and is a base 2009. Here are a couple of pictures of the plugs.
Old Jan 21, 2017 | 10:01 AM
mrbug's Avatar
mrbug
I decided to swap 3&4 coils with 1&2 to see if the problem would follow the coils. I did get another code for #2 cylinder misfire but not #1. I did pull the plugs to see if #3 was still wet. All plugs were dry this time. I wonder if the fluid in cylinder 3 was just carbon and gas? But when I pulled #4 it was dry and those were the two throwing the original codes. Since I haven't figured out how to reset the check engine light I don't know if 3&4 are still misfiring. These plugs have 33000 miles on them.
There looks like a little carbon build up on plug one.
Old Jan 21, 2017 | 02:07 PM
yesti's Avatar
yesti
Oil in there might be valve cover gasket blown, anyone else second that?
Old Jan 21, 2017 | 04:49 PM
mrbug's Avatar
mrbug
How about a way to reset the yellow engine warning light?
Old Jan 21, 2017 | 04:56 PM
yesti's Avatar
yesti
whoever scanned the code should be able to clear it. fix the problem first or it will just come back
Old Jan 22, 2017 | 06:30 AM
mrbug's Avatar
mrbug
It was scanned at Advance Auto so I don't know if they can/will. I was trying to isolate the problem to plugs or coils. I will replace both but just wanted to know which was the problem.
Old Jan 26, 2017 | 04:41 AM
Ronin1's Avatar
Ronin1
Put new plugs in it, replace the valve cover gasket and get the CEL reset.
Old Jan 26, 2017 | 05:54 AM
MiniToBe's Avatar
MiniToBe
+1
since the oil is covering the threads of the plug, the oil must be coming from the top hence the valve cover gasket.
a scanner is always a-must-have item. some times you cannot afford driving the car all the way to a shop for a scan to tell you something is wrong. you do not want to drive the car with a check engine light specially when the engine feels weak.
Old Jan 26, 2017 | 01:57 PM
Get the schwaben tool and you will be able to read ad clear down the road yourself.
https://www.northamericanmotoring.co...d-q-and-a.html
+1 Valve cover gasket or check the valve cover itself. (it might be cracked)
R57 Cooper (NON S ) N12 engine 11127567877
https://www.ecstuning.com/Search/SiteSearch/11127567877/
And replace those plugs.
R57 Cooper (NON S ) N12 engine 2009
https://www.ecstuning.com/Mini-2009-Cooper-R57-Base-Convertible-L4_1.6L_N12B16A/Engine/Ignition/
Old Jan 26, 2017 | 07:18 PM
mrbug's Avatar
mrbug
I ordered new plugs and coils from you and that fixed the miss. I will pull the plugs again after driving it a bit more to see if there is any more oil. I have to take the car in to get the top replaced so I will have the oil leaks checked. I got an extended warranty so I will have it fixed under warranty. Once I have these fixed I will be trading it. If that code reader would work on my Porsche I would buy it. Thanks for the help and link. Keep up the great service!
Old Jan 31, 2017 | 02:45 PM
Welcome. It will read general codes for the OBD 2 reader section on ALL OBD2 makes.
Old Feb 7, 2017 | 09:54 AM
mrbug's Avatar
mrbug
I had to get a couple of filters for my Cayenne so I decided to buy a gasket as well. Super easy to install and thanks for the link. If anyone hasn't seen the head on a 09 base here it is.
Top end on a 2009 base. 100,000 miles.
