07 MCS R56 Engine Blow At 99700ml
Old Jan 17, 2017 | 07:43 PM
guka747's Avatar
guka747
Soo Sh#t happend welcome to mini r56 life!!!
i was driving at highway trying to overtake and car started shaking,misfired and rattled.i pulled right a way and plug in obd2, error code was low circuit on cylinder 3.my first thought was coil.i ordered coil and before installation i decided to check spark plugs and BINGOO surprise!!!
Spark plug electrode on 3rd cylinder just felt down in cylinder and banged everything there
i decide to buy brand new engine I've got great deal on NAM !!!!!
best option for me
This will be HOW TO 2007 MINI COOPER S R56 DIY ENGINE REMOVAL AND INSTALLATION, maybe it will be helpful for somebody
Here we go
Bentley Manual and Pelican Parts tech articles are best friends to get this job done!
don't forget safety !!!!!!!
jack up car
remove both front tires
remove both liners
remove headlights
remove radiator support cover
put car on service position
i found oil in throttle body
turbo looks creepy :/
A/C radiator lowered not removed
radiator suport removed
remove turbo cover heat shields
my phone just died keep you updated MINIPEOPLE
Old Jan 17, 2017 | 08:32 PM
Semaphore's Avatar
Semaphore
Oh wow! How does that happen? Good luck with your project!!
Old Jan 18, 2017 | 05:37 AM
MiniToBe's Avatar
MiniToBe
Can you sue someone for these freaking spark plugs...I have two cars with same issue and i'm pretty sure there are more like this in the woodwork!
Although a straight engine swap is easy and fast, I would have tried rebuilding the engine. savings are at least %50.
Old Jan 18, 2017 | 06:14 AM
guka747's Avatar
guka747
yeah ive heard same about spark plugs but they were bosch thou.trust me in long term its a best option. trying to rebuild with quality it gonna cost almost same
Old Jan 18, 2017 | 06:37 AM
MiniToBe's Avatar
MiniToBe
I guess it all boils down to budget. keep them pix coming
Old Jan 18, 2017 | 08:09 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Sorry to hear about your misfortune, but it looks like you got a good grasp on the repair. I'm happy to see our articles have been super helpful to you during this process. Looking forward to seeing the finished product. If you need anything during this project please don't hesitate to let me know.
888.280.7799 | 6am - 5pm PST
Old Jan 23, 2017 | 06:50 AM
guka747's Avatar
guka747
hi Mini people
heres updates
ready for remove
Old Jan 23, 2017 | 08:15 AM
guka747's Avatar
guka747
Old Jan 23, 2017 | 08:16 AM
guka747's Avatar
guka747
those are exhaust valves it should be like this>>???
Old Jan 23, 2017 | 08:18 AM
guka747's Avatar
guka747
couple of weeks ago I've changed oil filter housing gaskets and it didn't stop leak. this was the reason , vacuum pump gasket
Old Jan 23, 2017 | 08:22 AM
guka747's Avatar
guka747
passenger side view
diconected thermostat hoses
Old Jan 23, 2017 | 08:24 AM
guka747's Avatar
guka747
ready to go
its free finally
Old Jan 23, 2017 | 08:25 AM
guka747's Avatar
guka747
thats it for now... waiting for parts :/
keep you updated
Old Jan 23, 2017 | 06:14 PM
timski's Avatar
timski
Quick question.
Looks like you didn't have to discharge the AC.
Is that correct?
I have taken out one MINI N14 engine but the AC was released during the accident.
I was hoping this time to put the car in service mode and remove the hood and not have to discharge the AC or remove the bumper.
Is that possible?
Comments?
Old Jan 23, 2017 | 06:33 PM
guka747's Avatar
guka747
Originally Posted by timski
Quick question.
Is that correct?
Is that possible?
Comments?
if u want to lower AC u have to put car in service mode and take off radiator support.
i didn't touch the AC because I don't want to take my chances,I had bad luck on my former cars,when i discharged/flushed AC they didnt work properly after that.
Old Jan 23, 2017 | 08:12 PM
timski's Avatar
timski
Ok. Thanks. The Bentley says to discharge the AC and I don't see the point (especially for us at home DIY'ers who don't have the machine)
From your pic it looks like the AC Condenser was simply unbolted from the block and then the engine removed. I will try this on my removal coming up. Thanks.
Old Jan 23, 2017 | 11:21 PM
Sstrickstein's Avatar
Sstrickstein
In middle or same project due to this guy. I decided to rebuild with quality pistons. New timing chain as well and clutch too. My engine is in bits right now. Taking cases and head to shop tommorow
Old Jan 24, 2017 | 09:40 PM
guka747's Avatar
guka747
i plan to rebuild my old engine, but first ive to look what it looks like inside. please keep updated
Old Jan 26, 2017 | 06:17 AM
MiniToBe's Avatar
MiniToBe
here is what I found when i rebuilt and engine for a NAM member.
Attached Thumbnails 07 MCS R56 Engine Blow At 99700ml-20161211_190504.jpg   07 MCS R56 Engine Blow At 99700ml-20161203_104534.jpg
Old Mar 18, 2017 | 06:22 AM
guka747's Avatar
guka747
sorry for late update
heres the pics , everything was went perfect when i putnew engine in, no error lights at all, i was surprised! car runs like dream
Attached Thumbnails 07 MCS R56 Engine Blow At 99700ml-img_3110.jpg   07 MCS R56 Engine Blow At 99700ml-img_3105.jpg
Old Mar 18, 2017 | 06:26 AM
guka747's Avatar
guka747
heres what i found inside. my first thought was that timing jumped and that caused problem but i was wrong, when i opened engine timing was perfect, chain, guides, was just fine.there was a lot build up
Attached Thumbnails 07 MCS R56 Engine Blow At 99700ml-img_3041.jpg   07 MCS R56 Engine Blow At 99700ml-img_3040.jpg   07 MCS R56 Engine Blow At 99700ml-img_3223.jpg   07 MCS R56 Engine Blow At 99700ml-img_3224.jpg
Old Mar 18, 2017 | 06:29 AM
guka747's Avatar
guka747
cylinder block
Attached Thumbnails 07 MCS R56 Engine Blow At 99700ml-img_3226.jpg   07 MCS R56 Engine Blow At 99700ml-img_3228.jpg   07 MCS R56 Engine Blow At 99700ml-img_3233.jpg   07 MCS R56 Engine Blow At 99700ml-img_3237.jpg   07 MCS R56 Engine Blow At 99700ml-img_3238.jpg
Old Mar 18, 2017 | 06:31 AM
guka747's Avatar
guka747
heres the cylinder piston #3
Old Mar 18, 2017 | 06:40 AM
guka747's Avatar
guka747
after all im planning to rebuld this engine.your help with this priject will be appreciated
after bore what oversize pistons u suggest ?
should i leave old rods all replace all4?
bent on cylinder is like deep im not sure its gonna be ok after bore? should i replace sleeve that possible on this engines?
i plan rebuild/clean/ head,replace burned valves,guides,valve stems,head studs,new timing chain,new gaskets.
what else ? i mean i never done this before and i need direction from what to start
thank you
Old Mar 18, 2017 | 05:41 PM
BigBoost's Avatar
BigBoost
Should have got a race-create motor
