Oil leak
Old Jan 12, 2017 | 01:02 PM
Minimedic501's Avatar
Minimedic501
Oil leak
I have a 09 Mini Cooper S while changing the oil the other day I noticed a lot of burnt oil on the bottom side of the motor. Could of this be due to a bad turbo oil feed line.
Old Jan 12, 2017 | 01:27 PM
3lusive's Avatar
3lusive
Turbo oil line, return line, oil cooler gasket, oil filter housing gasket, all common places that could leak oil. Turbo oil feed line you usually notice if there's burnt oil on the topside of the turbo where the banjo bolt is.
Old Jan 12, 2017 | 02:41 PM
Minimedic501
There is oil on the top were the oil line comes in to the turbo. There is more than you can tell from the pictures and looking from the bottom it looks like there is oul on the bottom of the turbo
Old Jan 13, 2017 | 07:42 AM
MiniToBe's Avatar
MiniToBe
the valve cover gasket seems to be leaking too? clean the area and inspect for new oil leaks...buy an after market oil feed line. I have been replacing them on all my rebuilds.
Old Jan 13, 2017 | 07:53 AM
Minimedic501
I'm going to to change the oil feed line and see if that fixes the problem. I can't figure out were the oil is coming from on the bottom I'm hoping it is coming down from the top and burning off before it hits the ground. Because every know and then you will see a few drops on the ground. Tge turbo is leaking oil some were.
Old Jan 13, 2017 | 08:23 AM
MiniToBe's Avatar
MiniToBe
it is also reported the oil filter housing gasket can leak and the same goes to the vacuum pump gasket. I think it is worth cleaning all of the above and spot new leaks
Old Jan 13, 2017 | 08:38 AM
Minimedic501
I'll give that a try I'm out of my element im not a mechanic by any meaning of the word. The oil line I think I can do but anything over that worries me.
Old Jan 13, 2017 | 08:42 AM
MiniToBe's Avatar
MiniToBe
There is a bit of work involved to get that replaced. if you DIY, you will be mechanic by the end of this journey. AND you will same a pretty dollar
Old Jan 13, 2017 | 10:19 AM
3lusive's Avatar
3lusive
I did the oil line replacement and it was tedious but doable with a friend. Buy this kit from detroit tuned, the oil line is designed much better:
http://www.detroittuned.com/dt-turbo...ine-super-kit/
When you have everything apart you might want to replace the oil cooler seals too. The oil cooler sits on top of the oil filter gasket:
http://www.detroittuned.com/mini-gen...-cooler-seals/
Took me approximately 14 hours with a friend. But that's also including intercooler and downpipe replacement. If I remember correctly you have to:
Remove upper/lower turbo heatshields
Remove downpipe
Remove heatshield behind downpipe
Then you have access to everything. Drain the oil and coolant before you start, when you disconnect the oil filter housing coolant will gush out everywhere.
Old Jan 13, 2017 | 12:38 PM
Minimedic501
Sounds like I need to replace every seal that has to do with oil lines.
Old Jan 14, 2017 | 01:06 PM
Minimedic501
Well today while I was trying to clean the oil up so I could of track the were it was coming from I noticed a cooling leak so took off a the pipe going to the air box and found this it looks like the oil and antifreeze is mixing some were
Old Jan 14, 2017 | 01:38 PM
Minimedic501
Could this be turbo seals
Old Jan 16, 2017 | 07:16 AM
MiniToBe's Avatar
MiniToBe
are you loosing antifreeze?
Old Jan 16, 2017 | 08:22 AM
Minimedic501
I saw sone pooled up on the transmission
Old Jan 23, 2017 | 12:50 PM
mrbug's Avatar
mrbug
I feel for you. Oil leaks seem to be a common problem. My 09 base was diagnosed with leaks coming from the valve cover gasket, timing chain tensioner gasket, vacuum pump, oil pan gasket and oil filter housing gasket back in the summer. I thought the dealer was just blowing smoke but now I have oil drops where the car is parked. Not to mention I may have oil leaking into the #3 cylinder. Only car I have ever had with under 100,000 miles that leaks oil. I never purchase extended warranties on cars but I am quite thankful my wife insisted on buying one for the Mini. It has been worth every penny.
Old Jan 24, 2017 | 04:39 AM
mbwicz's Avatar
mbwicz
If there is antifreeze on top of the trans, it is the thermostat leaking. This is a common problem.
Mike
