2 questions: x-lite center cap & tire decision
Old Jan 6, 2017 | 05:42 AM
TheAmericanJob's Avatar
TheAmericanJob
1. So I feel a bit dumb asking this, but is the center cap necessary on the x-lite wheels? I'm assuming it keeps dirt and debris out (preventing unnecessary wear) and should be there, but wanted to ask to confirm.
2. On those x-lite wheels (16x6.5 right?) what is the consensus street tire of choice? I am lowered 1in on tein s-techs. The car will not see any racing and these wheels will not be on in winter. Searching around here seemed like 215/50/16 would be good size for some extra grip over stock 195. I can go super aggressive with the compound and design as these tires will only be on in warmer months and it just isn't driven many miles. I would, however, like them to be decent in the rain when I get caught in a summer thunderstorm.
Thoughts on both would be greatly appreciated! Thanks!
Old Jan 6, 2017 | 07:40 AM
No dumb questions here. It's a good question.
Yea, keeps the lugs and the center bore / front of the hub center clean and water out. Also some people like the cleaner look, I have seen a bunch of people run without them , but that was autoX .
https://www.ecstuning.com/Search/SiteSearch/R84_MINI_X_Lite_Wheel/
Center cap R84 x-lite
https://www.northamericanmotoring.co...er-needed.html
I would run them unless its going to be a track set only or something.
195/55/16 on those wheels most of the time, here are some tire choices
https://www.northamericanmotoring.co...rchid=16132022
some people like the hankooks Ventus RS3 for the money
Old Jan 6, 2017 | 07:47 AM
TheAmericanJob
Does anyone make a smaller cover for just the center? I actually prefer the look without the covers. I plan to paint them this winter while they are off of the car.
Thanks for the response and links.
Old Jan 6, 2017 | 07:52 AM
iwashmycar's Avatar
iwashmycar
Just measure the diameter of that little hub circle. find caps that fit on eBay ect...likely another mini one would. Looks like most are 54mm http://www.dhgate.com/product/brand-...isc|3875393706
edit: or 50mm I guess https://www.ecstuning.com/b-genuine-...h/36131171069/
I dont think they are necessary...they only have the center hole in the wheel so that it can be put on a balancing machine. I think the hub assembly has sealed bearings anyway?
no, only thing i can think of it try to fit the center ***** from the steelies, but i dont know if the bore is the same aluminum wheels to the steeiles.
https://www.northamericanmotoring.co...now-tires.html
Welcome.
Old Jan 6, 2017 | 07:55 AM
TheAmericanJob
Sounds good guys. I suppose working in a tool and die shop I could simply design and make some for it (duh).
Any other tire suggestions?
Old Jan 6, 2017 | 09:27 AM
Alex@tirerack's Avatar
Alex@tirerack
205/50R16 is an ideal size. Bridgestone RE71 for aggressive drivers or BF Goodrich Comp 2 for slightly less agressive driving. Comp to is still a Z rated ultra high performance tire.
Old Jan 6, 2017 | 11:00 AM
TheAmericanJob
What do you all think about these 3 options:
1. Firestone Firehawk Indy 500
2. Firestone Firehawk Wide Oval Indy 500
3. BF Goodrich Comp 2
All in 205/50/16
They will all provide adequate grip for my needs based on ratings and reviews.
Old Jan 10, 2017 | 09:12 AM
Alex@tirerack
I'd rank them as follows
Firehawk Indy 500
Comp 2
Firehawk Wide oval Indy 500
The Indy 500's are my top pick due to the better blend of road noise and handling charateristics. Comp 2 is a slightly noisy. Other than wet braking modulation the Firestone was the top performer in our head to head test.
Indy 500 was developed in the Asian Market under a different label. It's a very predictable handling tire and the most current technology.
Wide oval Indy 500 is just an older, less competitive evolution. The price is outstanding however.
