15" steelies needed for snow tires !
Old Sep 18, 2013 | 07:18 PM
bacomeau's Avatar
bacomeau
HEY I NEED SOME 15" STEEL WHEELS FOR SNOW TIRES . sorry didn't mean to shout, but can I use VW rims off a Passat from 1998< 4 cly, 4 bolt pattern, 56.1 hub ?? Does anyone out there know if it's a fit or not. The Mini dealers have not sold any 15" for a 'long time' as I was told today.
Old Sep 19, 2013 | 05:59 AM
condor27596's Avatar
condor27596
I use 15s from a 1st gen MINI.
You can probably find them cheap.
Old Sep 19, 2013 | 06:32 AM
t-c-b's Avatar
t-c-b
if they're 4x100, and 56.1, they should fit; just try them on... you'd also need to know the rim size to fit tyres.
I found some 15" OEM Imolas quite cheaply, and I run those, as I think they look good and sort of old school. My dealer wanted to charge me EUR167 a piece. I think I paid less than that for 4 used but immaculate ones... it pays to look around.
Old Sep 19, 2013 | 06:37 AM
I believe the VW B3 & B4 Passast 1998 (4 cylinder ) and before have 4x100 pattern : 57.1 center bore. Best to double check on that.
If you are looking for OEM MINI steelies for Winter we have some options. Here they are for the 4x100 pattern 56.1 Center bore.
These are good for Gen 1 MINIs without the factory JCW front caliper.
Steel Wheel - Black 15 x 5.5 , Et45, 4x100 Part #36111511414
http://www.ecstuning.com/Search/SiteSearch/36111511414/
Steel Wheel - Silver 15 x 5.5 , Et45, 4x100 Part #36116768497
http://www.ecstuning.com/Search/SiteSearch/36116768497/
Center Caps for winter steelies.
Center Cap With MINI Logo In Chrome Part # 36136767398 And looks really good on the black 15" steelies.
http://www.ecstuning.com/Search/SiteSearch/36136767398/
MINI OEM part number :36116768504 Center Cap With MINI Logo In Wider Silver
This is great for the 4x100 silver face wheel to match, I am running the same set up on the factory 16".
http://www.ecstuning.com/Search/SiteSearch/36116768504/
[/URL]
Made for these: 16 x 5.5" steelies OEM part number: 36116764346 - Priced Each
( In 16" they come in silver , hence the silver match center cap ) These are good for Gen 1 With JCW brakes. Also Fits the Cooper & Cooper S Gen 2, but not the Brembo ( 4 pistion ) and GP2.
http://www.ecstuning.com/Search/SiteSearch/36116764346/
[/URL]
For the Gen 2 JCW Brembo brakes there are the Alloy skinny wheels . No 17" steelies at this time. Have not tested on the GP 2 JCW Brakes yet.
R114 JCW LM Rad Cross Spoke Wheel 17" (4x100) 17 x 5.5 ET:42 Part# 36116786220
http://www.ecstuning.com/Search/SiteSearch/36116786220/
Thanks and I hope that helps.
Emnotek
Aug 13, 2015 05:47 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
minipopkart
Aug 13, 2015 05:22 AM
ludedude
Aug 10, 2015 07:16 PM
