R56 Need Help with Clutch.
Old Dec 17, 2016 | 01:24 PM
Medevack1's Avatar
Medevack1
Hi guys I have a 2008 R56 and has 101k the clutch feels "spongy" when I press the clutch to the end it feels hard and I cant seem to get it into 1st gear. if i jam it into 1st gear it goes in after that all gears are fine, the Dot4 container is full, i checked the clutch slave cyl and there is no outside damage or leaking however i didn't take it apart. has anyone had this issue before? thank you all in advance.
Old Dec 18, 2016 | 12:02 AM
Mini Mania's Avatar
Do you know the last time the fluid was changed? If it is fresh, have you tried bleeding it? Is there any clutch slippage when driving?
Bleeding instructions can be found here.
http://new.minimania.com/Search_Results/clutch/default
Old Dec 19, 2016 | 09:18 AM
MiniToBe's Avatar
MiniToBe
did you check if the air or water pipes are in the path of the shifter cables (by the thermostat or oil filter housing) preventing from moving. Also, when you shift to 3rd or 5th from stop, do they go in smoothly or they struggle?
Old Dec 19, 2016 | 10:03 AM
Medevack1's Avatar
Medevack1
The R56 is an 08 with 102k miles, I don't think it has ever been changed. No I have not tried bleeding it yet. And no there is NO clutch slippage at all it pulls hard. Thank you very much for the help!!!!
All the pipes are good, I have not tried going into 3rd to 6th from stop. so far the only struggle is 1st.
Old Dec 19, 2016 | 09:53 PM
oldbrokenwind's Avatar
oldbrokenwind
When I had gear engagement problems, it turned out to be bad bushings on top of the transmission --- where the cables hook to the transmission levers. I did not have a "spongy" clutch.
If the gears grind and complain when you "jam" it, there's probably a clutch release problem. If it's only an engagement problem, with no gear-grinding noise, look for loose or mis-adjusted linkage.
Old Dec 20, 2016 | 08:38 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
How is your pedal travel? Does it seem long or abnormal? Definitely check your shift cables to make sure they're not binding, corroded or damaged. If you have never changed the transmission fluid, be sure to check out this link here: http://www.pelicanparts.com/techarti..._Replacing.htm. Grinding of gears could be related to old fluid breaking down too quickly or low transmission fluid. Since you've never replaced it, it may not be a bad idea to do so anyways. Process of elimination. Let us know what you find out.
888.280.7799 | 6am - 5pm PST
Old Dec 24, 2016 | 01:40 PM
Medevack1's Avatar
Medevack1
Well it looks like when i press the clutch pedal all the way i have trouble getting it in any gear even with the car running or off.
Old Dec 25, 2016 | 03:22 AM
jetsr6's Avatar
jetsr6
I would change out all the brake fluid and then bleed the clutch. The brakes diffidently need it anyway and I could feel a difference when I changed mine out with unknown miles as I bought my 2007 MCS used with 110,000 miles on it.
Old Dec 25, 2016 | 03:25 AM
jetsr6's Avatar
jetsr6
Oh and the original clutch in mine broke just before Thanksgiving with about 112,000 miles and my slave cylinder started leaking.
Old Dec 25, 2016 | 05:22 AM
Medevack1's Avatar
Medevack1
How could you tell your slave cylinder was leaking? Was it showing fluid, was it damp or dry? Here is mine.
Old Dec 25, 2016 | 10:09 AM
jetsr6's Avatar
jetsr6
Between the engine and trans case there is 2 little holes. Mine was leaking there. It leaks bad. It was also wet where the slave mounts to trans. Yours looks fine so no leaks.
Old Dec 27, 2016 | 06:56 AM
Medevack1's Avatar
Medevack1
So my slave cyl is good so what else can it be?
Old Dec 27, 2016 | 07:46 AM
jetsr6's Avatar
jetsr6
I would think it could still be worn out inside without leaking. But I'm unsure how to check that. I would still change out the brake fluid in all the brakes and then the clutch. They definitely need it.
Old Dec 28, 2016 | 02:02 PM
Medevack1's Avatar
Medevack1
Thank you
Old Dec 29, 2016 | 09:00 PM
grussell's Avatar
grussell
Is your clutch pedal almost all tge way out before engagement? We had these symptons right before the clutch plate failed. When I replaced the clutch one side of the clutch plate had worn down to the rivets and the material all came off and then there was no engagement.
