R55 Coding
Old Dec 13, 2016 | 02:14 PM
Scott Delaney's Avatar
Scott Delaney
Coding
I keep getting the following engine codes on my 12 clubman base...PO030, PO132 & P2414 Can anyone assist with what maybe causing these? Bad o2 sensor or something else? Also I thought I saw a post where Mini extended the warranty to 10years/100000mi on o2 sensors. Is this correct? I currently have roughly 76000mi on the car now.
Old Dec 14, 2016 | 09:11 AM
cargusjoh's Avatar
cargusjoh
Hi.. From the Bentley service manual, but I can't help to interpret them. Maybe others can hep with that part.
PO030
This has two MINI FCs of:
0x2A63 HO2S Heater Control circuit bank 1 sensor 1
0x2D0D HO2S Heater Control circuit bank 1 sensor 1
PO132
This has two different MINI FCs of:
0x2A98 O2 sensor circuit high voltage bank 1 sensor 1
0x2CFF O2 sensor circuit high voltage bank 1 sensor 1
P2414
This has two different entries with MINI FCs of:
Ox2ACB O2 sensor Oxygen sample error bank 1 sensor 1
Ox2CF8 Oxygen sense before catalytic converter, Installation: sensor is not installed correctly in the exhaust system
Old Dec 14, 2016 | 09:28 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
With all three codes being related to the O2 sensor, I would swap it out with a new one. You can try calling your dealer to see about the O2 sensor warranty before bringing it in. However, a new O2 sensor is an easy install.
Old Dec 14, 2016 | 10:11 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Although a Honda site, this doc shows emissions system parts coverage. http://owners.honda.com/Documentum/W...t/apl27540.pdf
Old Dec 14, 2016 | 01:14 PM
Should be covered : https://www.northamericanmotoring.co...o2-sensor.html
Old Dec 15, 2016 | 07:44 PM
Scott Delaney
Called dealer yesterday and they informed me there wasn't any extension of coverage on o2 sensors. I ordered 1 today. Hopefully that's my issue.
Old Dec 21, 2016 | 10:08 PM
Scott Delaney
Issue resolved. I cleared all codes then installed new upstream o2 sensor. No more codes or lights. Yippee!
