R50/53 Power Steering Recall Questions
Old Dec 11, 2016 | 11:36 AM
swiftycoop's Avatar
swiftycoop
The Mini Recall website shows that the Power Steering Recall #15V-660 has not been accomplished on my '03 MCS. I read the letter to owners and didn't see any drop dead date, is a vehicle as old as mine still covered by the recall? Also, for those of you who have had the recall done, how long did they have your car? Will I likely need to leave it with them for a day or two? Just curious because I'll have to arrange transportation home if I have to leave it with them.....I'm lucky(?) my DW does not drive...
Old Dec 11, 2016 | 12:25 PM
mdaz75's Avatar
mdaz75
If you call your MINI dealership with your VIN, they'll tell you if you're covered. When I had mine done it took them about 3 hours. I just sat and waited for it.
Old Dec 11, 2016 | 12:28 PM
chrisdurand's Avatar
chrisdurand
i just did the recall as well on a 2004 mc, you can give them the vin over the phone just to make sure, the service took 2 hours, i just waited for it to be done...
Old Dec 11, 2016 | 01:14 PM
swiftycoop's Avatar
swiftycoop
Thanks guys, I will call my nearest dealer. Two or three hours isn't bad at all. I just put on 2 new PS hoses because mine here weeping fluid.
Old Dec 11, 2016 | 02:14 PM
Kaniyrret's Avatar
Kaniyrret
Just had my 03 done, easy. Actually they brought it up while I was there picking up a new key.
Old Dec 11, 2016 | 04:35 PM
JCdubGerm's Avatar
JCdubGerm
The recall involves R50, R52 and R53 models produced from September 12th 2001 to February 9th 2005. As long as you fall into that range they will check your pump. No mileage limit or anything.
Old Dec 11, 2016 | 04:54 PM
swiftycoop's Avatar
swiftycoop
Did any of you have any parts changed due to the recall or just an inspection. Wonder what their criteria is for pump or fan replacement. Thanks for your help!
Old Dec 11, 2016 | 04:59 PM
mdaz75's Avatar
mdaz75
New pump installed. The old one had already crapped the bed when I brought it in.
Old Dec 11, 2016 | 07:50 PM
JCdubGerm's Avatar
JCdubGerm
The pump gets inspected. If it's one of the bad part numbers you will get a new pump , fan and harness if it's bad too. If the pump is fine you don't get anything .
Old Dec 12, 2016 | 06:00 AM
Mike87's Avatar
Mike87
They put a new pump and fan on mine. Even gave me a loaner car for overnight (I dropped my car off at 3:00 pm in the afternoon) Picked up my car the next day. They offered to do a lot more work at significant $$ but I declined.
Old Dec 12, 2016 | 06:13 PM
MiniTigger's Avatar
MiniTigger
I guess mine's not covered .. October 06.
Old Dec 12, 2016 | 10:11 PM
BTK's Avatar
BTK
Bought my 03 1.5 weeks ago, had the recall done Friday. They replaced the pump and fan, no harness. Took 3hrs. Easy peezy. My closest dealer is 2hrs north, up into Canada. Still real easy.
