R56 Mini-Cruze 1.4 Turbo
Old Nov 30, 2016 | 07:11 AM
corykueber's Avatar
corykueber
Stay tuned- 2008 cooper S with Chevy Cruze drivetrain!
In the process of replacing the junk 1.6 turbo engine with a 2012 cruze 1.4 turbo and 6 speed trans.
Old Nov 30, 2016 | 07:42 AM
Dr. Spade's Avatar
Dr. Spade
My mind does not know how to process this
Old Nov 30, 2016 | 07:43 AM
nkfry's Avatar
nkfry
Interesting..
Curious to see how you integrate all the electronics as well.
It'll be slower, but those EcoTec engines are fairly robust little guys.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Nov 30, 2016 | 07:53 AM
corykueber's Avatar
corykueber
There's actually more room under the hood with the cruze engine.
I will be using both engine management systems.
Old Nov 30, 2016 | 08:29 AM
randeez's Avatar
randeez
Nice
Old Nov 30, 2016 | 11:12 AM
Like a rare euro 1.4 MINI One version but in the Gen2 variation. Good luck on the swap.
Old Nov 30, 2016 | 11:22 AM
corykueber's Avatar
corykueber
Thank you!
Old Nov 30, 2016 | 12:11 PM
Welcome. Never seen anything like this on a MINI and I have seen allot of MINIs.
Old Dec 12, 2016 | 07:29 AM
corykueber's Avatar
corykueber
Front engine brackets
Plasma cutter is sure nice to have around! These are the engine brackets I made for the front of the engine above the harmonic balancer.
Old Dec 12, 2016 | 09:27 AM
AFN704's Avatar
AFN704
What is the goal with this engine? Just more reliability? I'd like to see someone swap like a Honda B16 and boost it.
Old Dec 12, 2016 | 12:49 PM
corykueber's Avatar
corykueber
Reliability, Parts availability, Parts cost. There's a lot of Chevy cruze's on the road! Engines and tranny's are cheap and available anywhere. Just about any parts store will have replacement parts.
Old Dec 12, 2016 | 02:29 PM
Bleedsblue's Avatar
Bleedsblue
Well flippin' cool! I'll bookmark this. Can't you get a fair bit of reliable power out of that engine with bolt-ons and tuning? Getting anywhere close to stock power would be the cherry on top of an actually reliable engine.
Personally I'd go NA Honda like I've seen before, but this is also awesome.
Old Dec 13, 2016 | 12:49 PM
imncrxtc's Avatar
imncrxtc
The oil filter is in the same location, i wonder who makes that engine for GM.
Old Dec 14, 2016 | 07:47 AM
R56BrgMcs's Avatar
R56BrgMcs
I like this. The prince engine is junk.
Old Dec 14, 2016 | 02:08 PM
SODA66's Avatar
SODA66
Keep us posted. Hope it works
Old Jan 9, 2017 | 01:17 PM
corykueber's Avatar
corykueber
Latest on mini-cruze
Lots of progress. Made trans mount utilizing a GM turbo 400 trans mount and fabricated bracket. Torque mount is fabricated and welded in. Used an S-10 blazer torsion bar mount. Believe it or not, But the BMW clutch pipe actually snapped into the GM clutch slave! Ball sockets on shift cables snapped onto cruze transmission as well. Mounted the cruze ecm off of drivers side frame rail. I also used new cruze radiator hoses that went right on the cooper radiator. More to come.
Old Jan 9, 2017 | 01:19 PM
corykueber's Avatar
corykueber
Photo of top
Old Jan 9, 2017 | 01:21 PM
corykueber's Avatar
corykueber
turbo
New turbo
Old Jan 9, 2017 | 01:22 PM
corykueber's Avatar
corykueber
ecm mounting
Mounted off drivers frame rail.
Old Jan 9, 2017 | 04:00 PM
MannyJimenez's Avatar
MannyJimenez
I long before you fire it up?
Old Jan 9, 2017 | 04:19 PM
corykueber's Avatar
corykueber
Startup
Hope to have it running by weeks end.
Old Jan 9, 2017 | 09:01 PM
scott13's Avatar
scott13
Best of luck. I'm enjoying reading about your progress.
Old Jan 15, 2017 | 03:43 PM
corykueber's Avatar
corykueber
Help! bentley or wds diagrams?
Now wiring the mini-cruse, is anyone willing to share the circuit explanation for the power and ground schematic? I have the diagrams, but no circuit number explanation. Thank you! Wiring is the last major hurdle in this project.
Old Jan 15, 2017 | 04:28 PM
Semaphore's Avatar
Semaphore
That's so cool! I wish I could help with wiring...
Old Jan 25, 2017 | 07:23 AM
corykueber's Avatar
corykueber
Almost there!
Finally got the new ecm flashed and tuned to eliminate VATS. Throttle is actuating and I now have 5volt references. I just have to run a fuel return line and install a fuel pressure regulator and get the drive axles adapted. The biggest pain of the project was the wiring but I worked through it.
Attached Thumbnails Mini-Cruze 1.4 Turbo-img_3709.jpg   Mini-Cruze 1.4 Turbo-img_3710.jpg
