R55 Rear trunk cover...
Old Nov 30, 2016 | 05:32 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Rear trunk cover...
Can anyone confirm for me if these two items are interchangeable?
P/N 51462758295
https://www.ecstuning.com/b-genuine-...k/51462758295/
P/N 51467263866
https://www.ecstuning.com/b-genuine-...k/51467263866/
I just bought a Clubman, and the rear trunk cover was broken. I want to replace it, but the ~$500 price tag for the retractable version is a little hard to swallow. I can live with the fold-able version, if I can confirm it fits before ordering it.
Old Dec 8, 2016 | 09:27 AM
bugeye1031's Avatar
bugeye1031
Moderator
Wish I could help you.....only know about the earlier version. I can tell you that on the early (less expensive) version that the cover has two pins on the end of the rod that fits next to the back seats. The pins are oval shaped and you pivot them into a "slot" in the trim that is mounted to the sides of the boot. the "slot" has a piece of plastic that is spring loaded to hold the pins in.
Old Dec 8, 2016 | 10:27 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
the later version mounts the same way at the front, and the rear has a couple of pins that catch the slots on the side. I'm almost convinced that the only difference between the two is the later version retracts.
Old Dec 8, 2016 | 11:21 AM
They are the same, one is just the newer LCI version that retracts. It was an upgrade in design by MINI. lots of people liked that.
http://www.realoem.com/bmw/enUS/show...35#51467263866
Old Dec 8, 2016 | 03:34 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Do you have one in stock?
Old Dec 9, 2016 | 06:49 AM
Not right now, but we can get it.
Some more info and pictures here:
https://www.northamericanmotoring.co...8-clubman.html
