R50/53 Vents on Dash hot!
Old Sep 20, 2004 | 06:40 PM
Lost240's Avatar
Lost240
Vents on Dash hot!
Are the vents on the top of your dash in the cooper S constantly pushing out hot air? Is there something wrong with my S?
-Justin
Old Sep 20, 2004 | 06:51 PM
JoeDentist's Avatar
JoeDentist
I guess it depends on what your heater or defroster is set to. Is everything off?
If you send the air conditioned air upward, is the air still hot?
Old Sep 21, 2004 | 02:32 AM
luckblackbird's Avatar
luckblackbird
all of them do this,u'v to close vents in order to hinder this.
even u turn off air condition,it pushs out air.
Old Sep 21, 2004 | 04:48 AM
ZAKdog's Avatar
ZAKdog
if you have auto a/c, try turning the auto system on, then turn the recirc (bottom) button on, then turn the a/c button (middle snowflake) off. That has been discussed to stop the hot air and does so with some effect.
Don't know why it does that...heat in the cabin in Florida summers is not welcome
Old Sep 24, 2004 | 10:37 AM
kiki511's Avatar
kiki511
As I've said before, the Auto AC system has a mind of its own and is a COMPLETE MYSTERY!!
Old Sep 24, 2004 | 11:08 AM
tech-gi's Avatar
tech-gi
hot air
I have an early 04 S and have the same problem.
I usually do't use the ac.
It's worse when car is hot.
I did notice an increase in heat after I put in the Alta CAI.
Do you have one?
Or have you mod'ed the engine compartment?
Old Nov 29, 2004 | 10:18 AM
sorsha6's Avatar
sorsha6
i'm bumping this thread as i noticed the same thing the other day. it's chilly out, about 45 and i turned off the climate control as the car was in the sun and it was ok inside... next thing i know i'm getting hot air blown in my face with the auto climate completely off... is it from the engine or what??
i turned on the auto and then shut off the air and it was ok, but still, what the heck?
thanks
Old Nov 29, 2004 | 10:29 AM
countrym's Avatar
countrym
Even if your ACC is off, it will still push hot air if it was heating the cabin when you turned it off.
Try turning on the ACC and setting it to "LO" for about 20 seconds. Then turn the whole thing off. The air coming out of the vents should be approximately outside air temperature.
I had this same question when I got my MCS. It's just a weird quirk of the ACC, not a malfunction.
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
potterstein
Oct 1, 2015 07:10 AM
