R50/53 HELP!Is this R53 overheating ?!
Old Nov 24, 2016 | 05:19 PM
j_mendieta's Avatar
j_mendieta
Hi all!
Is this mini over heating ?
I'm Interested in buying a 2005 mini s with 150k miles .. I wasn't sure if it was over heating. It sat @ 140 degrees when I turned it on then after driving it moved up between 140 and 250..
I've tried searching but I figure someone can give me a quick answer
Thanks in advance !
-Jason
9092748689. Please call me !
Old Nov 24, 2016 | 05:31 PM
Racingguy04's Avatar
Racingguy04
I can't call you because I'm in a different country, but I don't think it's overheating. The normal operating temp is around 200-220 degrees so as long as it sits there and doesn't climb higher you're probably good.
Old Nov 24, 2016 | 05:51 PM
j_mendieta's Avatar
j_mendieta
thanks for the reply
Old Nov 24, 2016 | 06:56 PM
Rich.Wolfson's Avatar
Rich.Wolfson
I'd say they designed it so straight up is normal.
///Rich
Old Nov 24, 2016 | 07:08 PM
j_mendieta's Avatar
j_mendieta
///Rich
tempted to just go pick it up lol..
need at least 1 person to confirm its normal
Old Nov 25, 2016 | 02:38 AM
Huge Fun's Avatar
Huge Fun
I agree with Racingguy04. Right around 200 is my usual experience, plus or minus a little.
Old Nov 25, 2016 | 04:32 AM
Piff's Avatar
Piff
I have a 06 with the chrono pack also and thought the same thing as you when I first got it. It's perfectly normal to be straight up and down, I agree it does however look misleading as most cars set the normal temp to be in the middle.
Old Nov 25, 2016 | 09:52 AM
mdaz75's Avatar
mdaz75
I know it doesn't look right, but it is. I have the chrono pack and mine runs hotter than that in the summer months. Seeing the needle that close to redline takes a little getting used to.
Old Nov 25, 2016 | 10:13 AM
j_mendieta's Avatar
j_mendieta
Thanks for the quick reply everyone !
After seeing 6 mini coopers im finally a owner of a 05 Mcs!
Jason
Old Nov 25, 2016 | 01:12 PM
mdaz75's Avatar
mdaz75
Congrats.........don't forget to post up some more photos!
Old Nov 25, 2016 | 03:31 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Congrats, that is perfectly normal as that is about 190. If you want a real temp gauge we recommend the Scangauge II as it gives you the temp down to the degree.
Old Nov 25, 2016 | 03:44 PM
j_mendieta's Avatar
j_mendieta
Here she is.. <br/>156k miles on chassis . <br/>80k on swapped motor(supposedly, no proof). <br/>6speed <br/>Clean title <br/>Clean car fax<br/><br/>Hope i got a decent deal @ $4k<br/><br/><br/>
Old Nov 25, 2016 | 04:21 PM
mdaz75's Avatar
mdaz75
I've always liked the black on black! That's what I was originally looking for when I was searching.
