R50/53 Let's Play: Can You Identify This Leak?!?
Old Nov 10, 2016 | 01:39 PM
Kief's Avatar
Kief
Noticed a small leak under my '06 JCW w/62k miles. Just got the car a month ago. PPI did not discover any leaks and it's been worked on since to repair typical wear items, cooling fan, bushings, mounts, etc.
I was away last week and decided to place cardboard under car as it sat for a few days.
So name that leak...
Old Nov 10, 2016 | 01:43 PM
JAB 67's Avatar
JAB 67
power steering fluid.
Old Nov 10, 2016 | 01:54 PM
Kief's Avatar
Kief
Interesting....b/c I've been bitching about my steering since I got it. The "typical mini whine" and feel. I even made a separate thread and video about it
https://youtu.be/i3afSIld9Uo
https://www.northamericanmotoring.com/forums/r50-r53-hatch-talk-2002-2006/308809-power-steering-or-differential.html
Old Nov 10, 2016 | 02:21 PM
nkfry's Avatar
nkfry
^^Powersteering fluid,
I'd ask if it was into the dealer recently for the EHPS warranty work, but you're not covered by it. Start by looking at the powersteering return line (rubber hose crimped to a steel line) it is the most prominent leak in the PS system.
Powersteering Return Line
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Nov 11, 2016 | 03:37 AM
Kief's Avatar
Kief
Links didn't work above--I guess b/c I was on mobile
https://www.northamericanmotoring.co...ferential.html
Old Nov 15, 2016 | 09:07 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
The power steering lines themselves can be a problem area as well and leak. Check the return and suction lines. #1 and #11 on the diagram below. Be sure to also inspect the pump and rack itself for any signs of leakage as well.
http://www.pelicanparts.com/techarti...eplacement.htm
#11 is the return line HERE
#1 is the suction hose HERE
888.280.7799 | 6am - 5pm PST
Old Nov 15, 2016 | 10:03 AM
Kief's Avatar
Kief
Thanks for the links. Upon looking more closely, it does look like it's one of the lines. Looks like a small puncture/hole where the clamp is installed. Plenty of PS fluid in the reservoir. Getting it taken care of tomorrow.
Old Nov 16, 2016 | 01:46 PM
GearheadS's Avatar
GearheadS
It's often just that the rubber shrinks a little and the clamp needs tightening. Except you can't tighten this type of clamp. So I removed those clamps (4 of them) and installed normal worm clamps. That took care of 98% of the leak, now it just makes a little oily film on the hose but never runs anywhere.
Jeremy
