Location of TCU/TCM module?
Old Oct 31, 2016 | 02:31 PM
Sigboi's Avatar
Sigboi
Hey everyone,
My 06 MCS popped a 0700 code, and luckily my scanner can read in depth and it shows "Aisin TCU OBD relevant fault".
I wanted to ask if anyone knows where this module is located. Realoem doesn't have any diagrams for its location unfortunately.
Thank you!
Old Oct 31, 2016 | 04:36 PM
sarom058's Avatar
sarom058
From: Portland, OR *currently in a temporary email address
I remember seeing a box like that inside the trunk, underneath the plastic cover that goes over the truck latch/lock. Try there!
Old Oct 31, 2016 | 04:57 PM
Sigboi's Avatar
Sigboi
Found it!
Thanks for the input, it turned out to be under the steering wheel panel, up against the firewall.
Rigged up another unit and the car is running good again!
Old Aug 16, 2018 | 12:35 PM
Hisphredness's Avatar
Hisphredness
Silly question but was it a simple unplug and plug in the new one or is there more technical work to do with the electronics?
Old Aug 17, 2018 | 12:02 PM
Sigboi's Avatar
Sigboi
Unit was behind the pedals and higher up against the firewall. It is straight forward, just bolts, but due to location you have to reach at awkward angles to get at them. On this car, no coding was needed, just plug and play. Hope this helps!
Old Aug 17, 2018 | 04:45 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I wouldn't chase the TCU as that fault is a generic fault and doesn't mean the TCU is bad. You need to get the real BMW software to find out what the real codes are and fix them. As you will find you will have more codes with it than just the 700 fault
Old Oct 26, 2019 | 09:43 PM
Rush2252's Avatar
Rush2252
Here is a good link for anyone having transmission issues on the r56 automatic, this applies to the clubman R55 and S model r56.
Old Oct 27, 2019 | 12:53 AM
Shawn Hussey's Avatar
Shawn Hussey
Where is this?
https://youtu.be/v4_1RJUcjI4
Where is this connection?
Old Aug 10, 2024 | 10:00 AM
aRussianDennis's Avatar
aRussianDennis
Will the neutral mode vanish after cleaning the wire connections?
does anyone know if I have to do anything special after cleaning like resetting the system or does it automatically reset with a solid connection?
