R50/53 Valeo conversion kit won't fit?
Old Oct 27, 2016 | 07:57 PM
Lemoneminems's Avatar
Lemoneminems
Hello All,
It's been a while since I've last posted, and unfortunately i come bearing bad news. A couple of weeks ago, my clutch started slipping, and while on accelerating on an on ramp, it totally crapped out on me. After doing some research, i decided to go with the Valeo single mass conversion kit as it had decent reviews at a price point that couldn't be beat. After receiving it and dropping it off to my mechanic, I received a call a few days later. From what i understand, the Valeo flywheel is supposed to be the same dimensions as the oem, but that wasn't the case I have attached pictures showing the difference in thickness between the 2 (Valeo on the right, hem on the left). As you can see the Valeo flywheel is roughly a quarter of an inch thinner than the poem flywheel. Any insights? Not too clutch savvy, so any help is appreciated!
Attached Thumbnails Valeo conversion kit won't fit?-unknown-1.jpeg   Valeo conversion kit won't fit?-unknown.jpeg
Old Oct 28, 2016 | 06:38 AM
nkfry's Avatar
nkfry
It will be fine, we have sold and installed hundreds of the Valeo kits, just tell them to install it as per the instructions, and you'll probably need to bleed the slave (or replace it as it is probably going to fail when they reinstall it.)
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Oct 29, 2016 | 01:41 PM
Lemoneminems
I had my mechanic install it and it didn't work. no matter what he did, it would not go into gear. after looking at the parts I received and comparing them to pictures online, the flywheel I received looks slightly different. I have attached two pictures to compare.
Attached Thumbnails Valeo conversion kit won't fit?-screen-shot-2016-10-29-at-4.29.08-pm.png   Valeo conversion kit won't fit?-unknown-5.jpeg
Old Oct 31, 2016 | 05:43 AM
gjxj's Avatar
gjxj
did he bleed it
Old Oct 31, 2016 | 06:31 AM
nkfry's Avatar
nkfry
Sounds like the slave failed, or there is a large amount of air in the system.
Like I said earlier; the slave is probably failed and needs replaced, they don't fair well to being removed and installed multiple times.
MINI Cooper S Slave Cylinder
Phone:586-792-6464
Old Oct 31, 2016 | 12:19 PM
BlwnAway's Avatar
BlwnAway
Ditto on the slave cylinder, they are a real PITA to bleed, and very fragile when trying to reuse one, even my new one took 4 separate bleeds with the power bleeder to get right.
Old Jun 17, 2021 | 03:14 PM
Pierfranco's Avatar
Pierfranco
Hi, I have the same problem.
The disc doesn't engage and the slave cilinder it's bleed after me from a mechanic.
I saw before install that the flywheel it's less height of original dualmass.
The problem it's from less height? The bearing doesn't arrive to pull the clutch because there is more distance with flywheel monomass?
I have R52 S 125Kw year 2004 and the Valeo kit that I buied it's 835024.
Old Jun 19, 2021 | 08:16 AM
Crushercurtis's Avatar
Crushercurtis
Any updates? I'm probably going to install mine in the fall.
