R56 215/45/17 to big of a tire for a stock mini s?
Old Oct 25, 2016 | 07:17 PM
Scooter24's Avatar
Scooter24
I had 205/45/17 on my car and I just got winter tires today, they orderd 215s they said it was easier to find. I said ok sounds good. Well on the way home I took the normal route and when i went over a wavy spot in the road it sounded like I was rubbing on the back right wheel. I said "wtf" so i turned around and I didn't see anything i could of hit. While going over again it did the same thing. When I got home I looked that's when i noticed the fender was bent up on the inside of the wheelwell back by the bumper. I dont remember it being that way maybe it was and with the little wider tire it's just now being able to make contact. Or it was from the tire?. Idk I bent my it back by hand. But is anyone else running a 215 on a stock s? Thanks
Old Oct 25, 2016 | 10:34 PM
kaneguy's Avatar
kaneguy
With stock wheels with 48mm offset should fit. Most after market wheel max out around 42mm offset and they may rub with those size tires.
Old Oct 26, 2016 | 03:17 AM
Scooter24's Avatar
Scooter24
I figured they would and it doesn't look like they will rub but for the edge of the fender tk be ben up a little confuses me. I dont remever seeing it before. Then again it was a small bend and maybe I just never noticed it before.
Old Oct 26, 2016 | 05:17 AM
Qik420's Avatar
Qik420
I've been running 215/45's for the last 8 months with no rubbing. I put some aftermarket wheels with a bigger offset and they did rub with that size tire, but went back to stock wheels and still no rubbing even with a 10mm spacer.
Old Oct 26, 2016 | 05:37 AM
digitaldagor's Avatar
digitaldagor
Qik420 could you post a picture?
Old Oct 26, 2016 | 06:40 AM
Qik420's Avatar
Qik420
digitaldagor
Thank you!
Old Oct 26, 2016 | 10:12 AM
Minibeagle's Avatar
Minibeagle
Been running that tire for years on my R53. Absolutely no fitment issues.
Old Oct 26, 2016 | 11:05 AM
scottselk's Avatar
scottselk
If you use this tire calculator you will find they are not much bigger.
Scott.
Old Oct 26, 2016 | 12:27 PM
Scooter24's Avatar
Scooter24
Yeah I knew it wasn't much bigger just the whole rubbing noise Threw me off.
Old Oct 26, 2016 | 01:10 PM
Big Jim Swade's Avatar
Big Jim Swade
I've been rubbing them on my clubman S for a few years with never any rubbing.
Old Oct 26, 2016 | 02:28 PM
nkfry's Avatar
nkfry
As many have stated, the 215/45/17 has become rather standard as a replacement to the 205s as it has a bit more sidewall for ride as well as doesn't deteriorate handling.
I'd say the snow tires are your biggest reason for hearing noises, as the treadblocks tend to be a bit larger and protruding.
The only time I rub on my car is either when I've got sizeable luggage, more than 2 people in the car, or if I'm on twisty roads having...Fun.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Oct 26, 2016 | 04:39 PM
isamin's Avatar
isamin
I have been running 235/40/17 on 7.5 wheels and lowered 2" for about 4 years with never a problem. The key issue is wheel offset and backspacing.
ISAMIN
p.s. if someone can tell me how to use the computer to post pix I'll show you how to make your ride BADASS and the NV of all boy racers.
Old Oct 27, 2016 | 08:11 AM
xSpartanCx's Avatar
xSpartanCx
ISAMIN
You could upload a picture to imgur.com and post a link into here.
I just picked up some ASA JH3 16x7.5 ET38 and am looking for the widest tires I can get without rubbing for autocross. What's the offset on your wheels?
Old Oct 27, 2016 | 10:45 AM
isamin's Avatar
isamin
17x7.5 ET 45 Rota RB. iuse 12.5 spacer up front to clear the Brembos and are mounted using long screw in STUDS. No spacers in back
ISAMIN
Old Oct 28, 2016 | 01:09 PM
Saovalle's Avatar
Saovalle
Not at all! I run a 225/45/17 on my stock MCS with the Challenge wheels. The 215/45/17 look great on the mini too! :D
Old Oct 28, 2016 | 01:24 PM
miniuy's Avatar
miniuy
+1 on the great look running 215/45 R17.
IMHO, Challenge wheel are the best.
I just moved to 215/45 r16 to have more clearance on a wider wheel (8 inches)
