R56 Sun Roof Help
Old Oct 24, 2016 | 11:10 AM
crosby's Avatar
crosby
Sun Roof Help
Hey There...
My Sun Roof will not open now.
I have a 2007 Mini Cooper Base R56
It makes a horrible grinding noise.
Any Ideas?
File Type: mov
Old Oct 24, 2016 | 02:39 PM
Fly'n Brick's Avatar
Fly'n Brick
Just my WAG factor deployed but that sounds like gears grinding or slipping. Just reading without the audio available I was ready to suggest a good dry lube for the rubber guides but you've got more going on there.
Have you tried 'helping' it at the same time you push the button?
Old Oct 25, 2016 | 06:26 AM
Some help here:
https://www.northamericanmotoring.co...k-on-07-s.html
Its jammed and the motor is jumping the cable teeth. You might have to nudge it and hose it down with grease.
Old Oct 25, 2016 | 10:58 AM
crosby's Avatar
crosby
Yeah, I tried Nudging it and kept doing this. Man thats a pricy motor but I kinda get why it is. Do they make gear kits by any chance?
Thanks so much,
crosby
Some help here:
Old Oct 25, 2016 | 11:19 AM
No kit just the motor and then the cassettes cables / main frame as one.
Old Oct 26, 2016 | 10:09 AM
crosby's Avatar
crosby
OK, Thanks so much...
Old Oct 26, 2016 | 12:33 PM
MazMini's Avatar
MazMini
Mine is doing the same thing I thought I had to buy a new sunroof but I will try and manually opening the sunroof and greasing it tonight..
Old Oct 28, 2016 | 07:33 AM
odieman23's Avatar
odieman23
Up and Down
Ok, so what and up and down motion when you first start the car?
So when I first start the car at any part of the day...I try to open the sunroof and all it does is "tilt up and comes back down"...and it will continue to do that ...so what I do is: I drive for about 10 mins and try again and it works perfectly.
If I turn of the car and start again it works, I guess is when the system is de-energized for a long period.
