Power Steering Pump
Old Oct 24, 2016 | 04:56 AM
malsalah's Avatar
malsalah
Power Steering Pump
Hello All..I have a 2006 Cooper S Convertible. I notices this past weekend while driving in nice warm Michigan fall weather, that the steering is kind of tough to steer, also I can hear a winey noise as I am turning the steering left or right. Is this a sign of faulty power steering pump? I checked the power steering fluid and it's okay. How do I know if it's time to replace it. Are those expensive? where is best place to get one? replace one?
Thank you so much.
Old Oct 24, 2016 | 02:33 PM
Omer Humayun's Avatar
Omer Humayun
Best thing to do is to get it checked by a MINI specialist, dealer or otherwise.
If it is the pump that needs replacing, "expensive" can be a relative term.
If mine ever goes, I will be considering the power steering delete kit.
https://www.condorspeedshop.com/prod...teering-delete
Old Oct 24, 2016 | 02:47 PM
GearheadS's Avatar
GearheadS
The pump is electric and only runs on demand. Spendy - yes. When mine went, and I think this is common, it just quit due to a failed controller. It's normal to hear the whine when moving the steering wheel, especially in a garage. And I find the MINI steering to be somewhat heavy feeling for a little car. Has yours gotten heavier?
Jeremy
Old Oct 24, 2016 | 03:08 PM
malsalah's Avatar
malsalah
Thank you. Didn't know you can do a delete to it. Probably because of the pricy repairs am assuming.
Old Oct 24, 2016 | 03:09 PM
malsalah's Avatar
malsalah
Jeremy
Thank you.
Old Oct 25, 2016 | 05:43 AM
For later 2005 and up models they were not covered by the service bulletin, but some options here:
https://www.northamericanmotoring.co...-loaction.html
Might be the fan or the pump :
https://www.ecstuning.com/News/MINI_...g_Pumps_19695/
Check the lines also, they might be leaking and you might just be low on fluid.
https://www.northamericanmotoring.co...hose-pics.html
Old Oct 25, 2016 | 06:30 AM
malsalah's Avatar
malsalah
Thank you so much for the information.
Old Oct 25, 2016 | 06:33 AM
Welcome. Fellow R52 owner here also.
