R50/53 Supercharger Air to Intake Duct Gasket
Old Oct 17, 2016 | 02:27 PM
ddye's Avatar
ddye
In testing my mini system for leaks I discovered that the little green gasket that goes between the supercharger and air intake duct was leaking. I went to BMW and bought a new one and reassembled and tested again. It still leaks with only 7 lbs of pressure. Anyone else run into this and found a solution? I inspected the intake duct itself and it does not have any cracks nor does it seem deformed. There is a little tab on the bottom with a hole in it that seems to need a screw but there is noting on the supercharger to screw into. This is the only place I am finding a leak.
Help appreciated.
Thank you,
David
Old Oct 17, 2016 | 02:39 PM
JAB 67's Avatar
JAB 67
There is certainly a spot on mine for that screw to fit into. Look very closely. I can send you a pic if you want. My car is currently disassembled so I get a good view.
Old Oct 17, 2016 | 02:54 PM
ddye's Avatar
ddye
Yes please sent a pic. I have a screw in the front but not on the underside.
Old Oct 17, 2016 | 03:33 PM
JAB 67's Avatar
JAB 67
Sorry; I don't have access to the underside, only the front.
Old Oct 17, 2016 | 04:39 PM
ddye's Avatar
ddye
No worries. Upon further testing I found that I have a Crack in the plastic air intake duct. Guess BMW is getting more of my money.
Old Oct 18, 2016 | 07:04 AM
nkfry's Avatar
nkfry
Don,
Those green gaskets leak even on a good day, evidence of them leaking is the oil that builds up around the mating surfaces of the intake duct to the SC.
I've seen a couple of those black intake ducts cracked as of recent, it seems the plastic welds are becoming brittle.
Let us know if you need any help, we should have one or two on hand.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Oct 18, 2016 | 07:31 AM
JAB 67's Avatar
JAB 67
What is the price for one of those intake ducts?
Old Oct 18, 2016 | 07:35 AM
nkfry's Avatar
nkfry
Last time we ordered them, retail was $142.88 on the manual, the automatic uses a different duct.
Phone:586-792-6464
ddye's Avatar
ddye
$200 at the dealership. I just replaced mine and the gasket and it is still leaking. Does it matter? All it is going to do is allow additional air to be pulled into the supercharger right?
Old Oct 18, 2016 | 08:45 AM
nkfry's Avatar
nkfry
The gasket doesn't seal perfectly, even when new and extremely clean they leak.
Not going to hurt you, if the car throws unmetered air codes or lean codes, etc, then you have larger leaks or problems.
Phone:586-792-6464
TJANK
Jul 31, 2019 06:23 AM
TJANK
Aug 18, 2016 02:55 AM
TJANK
Aug 15, 2016 11:28 AM
TJANK
Aug 10, 2016 11:46 AM
JAB 67
Aug 4, 2016 10:30 AM
