R56 Boost PSI
Old Oct 16, 2016 | 02:27 PM
odieman23's Avatar
odieman23
Boost PSI
who out there is running more than 20 PSI on their MINI??
I know the factory settings are about 12PSI but I'll like to know who out there is running 20 or more PSI of Boost?
Please share your MAX PSI set to your MINI
Old Oct 16, 2016 | 03:30 PM
mikeBURRITO's Avatar
mikeBURRITO
well... I have a few upgrades... and an Autometer boost gauge and sometimes i peg the boost gauge at 15psi.... for a stage 2 2010 MCS... no tune just bolt ons.
Old Oct 16, 2016 | 04:48 PM
odieman23's Avatar
odieman23
That's good to know...because there's two options when it comes to Boost gauges on auto meter:
-30 VAC / 20 PSI Boost
-30 VAC / 30 PSI Boost
I believe that the -30/20 is a good option, that"s why I asked the question....
Now as far as the Water Temp?
120/240 or 140/280?
Old Oct 16, 2016 | 05:46 PM
mikeBURRITO
120/240 or 140/280?
Yea, I'm going to get the mechanical gauge. I got the one that only goes to 15psi because I wanted a full sweep on my gauge. But installing it was a bit of a pain because it came with its own MAP sensor. Wish I had just gone with the -30/20 to begin with. It was cheaper too. But for the record, I never once saw my boost go above 13psi before my upgrades.
Old Oct 17, 2016 | 05:49 AM
odieman23's Avatar
odieman23
I guess I'm between having to buy the "Aeroforce Interceptor" gauges or the mechanical "Autometer Ultra Lite II" ... is a lot of money to be spent in gauges and I want to get the right ones
Old Oct 17, 2016 | 09:34 AM
nkfry's Avatar
nkfry
Autometer mechanical boost gauges are just fine, and cost significantly less than electric gauges.
I've run the Autometer Ultra Lite boost gauge in 3 of my previous vehicles, as well as my current MINI. Never a problem, always reads what I need it to.
Other than the possibility of needing a snubber to keep from getting air hammer readings on the gauge they are a quick and painless install.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Oct 17, 2016 | 10:10 AM
isamin's Avatar
isamin
where do you connect the 30/20 gauge and will it read just vacuum or just boost?
ISAMIN
Old Oct 17, 2016 | 12:40 PM
odieman23's Avatar
odieman23
an Adapter at boost port
as far as I know is the boos sensor and it will read as such...please someone correct me if I'm wrong...
Old Oct 18, 2016 | 06:58 AM
nkfry's Avatar
nkfry
ISAMIN
There is a couple of different options for quick fit boost taps, but my favorite is the NM Boost Tap (or equivalent). Once tapped it will read manifold pressure +/- all from the same port.
With one of the quick fit ports the hardest part of the whole job is successfully routing the teflon tubing and not kinking it.
Phone:586-792-6464
Old Oct 18, 2016 | 01:50 PM
Kalibdor's Avatar
Kalibdor
You're fine with 120/240 for water temps. If it's pegged at 240 you've got a serious issue. 231 is when the thermostat opens, so if it's climbing past that something's wrong.
And yeah with the boost gauge same concept. Unless you plan on heavy modding you shouldn't be running past 20, really past 18-19. So that decision would depend on your intentions with the car. Mine runs ~18 max, with intake exhaust intercooler and tune.
Old Oct 18, 2016 | 01:57 PM
odieman23's Avatar
odieman23
Awesome.. that really helps... I'll like to see some kind of sweep in my gauges...
I would hate to be concentrating on it to figure out the numbers.
TJANK
Jul 31, 2019 06:23 AM
TJANK
Aug 18, 2016 02:55 AM
TJANK
Aug 15, 2016 11:28 AM
TJANK
Aug 10, 2016 11:46 AM
snowmanmini
Aug 9, 2016 06:29 PM
