Rough idle
Old Oct 8, 2016 | 01:37 PM
mmelanson33's Avatar
mmelanson33
Rough idle
Okay so I was just driving my r56 on a small highway, and as I took the exit and it was a sharp right turn... going about 35-40mph, my oil light flashed on and shut off and now the car has a really rough idle. Any reason why this would happen? Car was running completely fine before the turn.
Old Oct 8, 2016 | 06:58 PM
njdangler13's Avatar
njdangler13
Check and top off your oil as needed. Sounds like you may be down a couple quarts causing incorrect oil pressure to the the vanos adjustment unit/solenoid. Start with the oil check/top off and let us know if it resolves itself.
Old Oct 10, 2016 | 05:18 AM
mmelanson33
car has oil.. i was thinking it could be the vanos solenoid.
Old Oct 10, 2016 | 05:20 AM
mmelanson33
car has multiple codes. multiple misfire, retarded timing, some camshaft code, and one for the vanos solenoid.
Old Oct 10, 2016 | 12:22 PM
Either that or your low on oil, when that happens it will flash. But you should be a normal idle once it's back to normal. It would also sound like a really bad timing chain rattle till the oil returns. I would check your oil asap. And scan the car with a good scan tool :
https://www.northamericanmotoring.co...d-q-and-a.html
Then see if you are get the Vanos code.
Vanos :
https://www.northamericanmotoring.co...-location.html
Old Oct 11, 2016 | 09:24 AM
mmelanson33
thanks for all of the input, ended up being the vanos solenoid.. replaced and the car is running fine
Old Oct 12, 2016 | 11:08 AM
MazMini's Avatar
MazMini
Yeah my vanos soleniod is bad and it will start and run fine but once its hot it will run like crap
Old Oct 12, 2016 | 12:40 PM
There is the older design and it does not have the little screen. That's how you can tell it you have the older vs newer design.
13WSCRJCW
Aug 3, 2018 08:08 PM
KWStan
Apr 13, 2018 02:57 PM
TheGreatOne
Oct 29, 2016 11:04 AM
TheBingoBalls
Sep 7, 2016 04:37 PM
richardsperry
Aug 31, 2016 11:38 AM
